problem after oil change??? HELP!
Old Jun 7, 2006 | 10:04 PM
ekstasis's Avatar
ekstasis
Default problem after oil change??? HELP!
brought the car to a local shop for an oil change, put in royal purple with kn filter. today when i was driving i can hear a "click click click" whenever i step on the gas. I hear it when in gear or in neutral!! so i checked the oil level. its so high?? its like 3/4 of the dipstick. first just got the car recently, dunt think that its suppose to be that high...its way way way above the high marlk
Old Jun 7, 2006 | 10:08 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
go back and tell them to do it over.
Old Jun 8, 2006 | 03:53 AM
guy121's Avatar
guy121
if you have too much oil in there, things can really get screwed up.
Old Jun 8, 2006 | 12:50 PM
ekstasis's Avatar
ekstasis
how do u read the oil pressure on this freaking car? weired dipstick, am i reading it wrong?
Old Jun 8, 2006 | 01:51 PM
zzz350's Avatar
zzz350
It is very difficult read compared to other cars. I simple pull out the stick and try to get the stick horizontal as soon as possible (same with my women). Then turn the correct side up to read the fill lines on the stick. There usually is a little residual oil left on the edge of the stick that will be up higher than the actual oil line on the stick. Good luck.
If you have excessive oil in the car, you need to drain some out immediately. Open up the drain plug a little until some oil starts seeping out, just don't remove the drainplug completely or you will be very sorry.
Old Jun 8, 2006 | 07:20 PM
Netko350Z's Avatar
Netko350Z
over time your VQ will burn it... mine does already
Uriyo_
Sep 8, 2021 08:46 AM
