Anyone Clean their MAF (mass air flow sensor)
Old Jul 1, 2006 | 08:26 AM
nothix's Avatar
nothix
yea im definatly considering a popcharger as my first aftermarket add on
Old Jul 1, 2006 | 01:08 PM
NiSmO21z's Avatar
NiSmO21z
Wink Cleaner
My friend car was boggin down and stuff. He went and bought the cleaner and it fixed the problem. So, I tend to clean it every other oil change. Y not? It can only help.
Old Jul 1, 2006 | 04:16 PM
pauley's Avatar
pauley
I tried the Crc cleaner on my G35 friday and i must say i'm glad i did.I feel the engine pulling smoother and stronger.I removed the mass air sensor itself to clean it(2 small screws) sprayed 8-10 times,let dry for few minutes and reinstalled.I have 22K+ miles on my car and i feel the car responding a whole lot better.All for 6 bucks and 10 minuties.
Old Jul 3, 2006 | 08:56 AM
andy2434's Avatar
andy2434
I used the CRC MAF cleaner on the MAF assembly, yesterday. The hardest part was tracking down the Torz 20 security bit to remove the 2 torx head screws. Other than that it's quite a simple process. I didn't notice much difference after the cleaning, but the MAF unit was quite clean clean prior to the cleaning. It's definitely worth the few bucks to keep everything in check.
Old Oct 7, 2006 | 04:05 PM
broohaha's Avatar
broohaha
The directions are pretty sparce. It says to spray 10-15 shots on the hot plate... whatever that is.
I think I screwed mine up. On the metal plate I noticed some slight white foam expanding around the edges(probably the seal for the main box.) It's very slight, so i'm hoping I haven't done any damage. To all others: I would just spray into the vents. I'm letting it dry overnight and will report on how bad I f'd it up.
Old Oct 8, 2006 | 01:35 PM
SpeedRcr's Avatar
SpeedRcr
there is the metal contact on the maf, spray that area...i had no foaming
Old Oct 19, 2006 | 05:12 PM
vchoward2's Avatar
vchoward2
well i use this exact product mass air flow cleaner everytime i clean the filter and it does seem to help the car breathe better. It doesnt hurt the engine at all, and when the filter gets dirty, combined with cleaning it and spraying on the maf cleaner you will notice a nice little gain. and the whistling sound from the jwt intake is fully restored.
Old Oct 19, 2006 | 05:16 PM
plumpzz's Avatar
plumpzz
Ever since this thread came out i did buy one. I do it every other time i clean the filter. Blue oil comes out from inside the maf Also, i clean the throttle plate every 2 oil cahnges too. The hot side is black with soot from blowby. Use TB cleaner not carb cleaner for the TB.
Old Oct 19, 2006 | 06:43 PM
DMK's Avatar
DMK
Where can I get this? I have been to Napa, Kragen and Pep Boys.
Old Oct 19, 2006 | 06:58 PM
thirty5ounces's Avatar
thirty5ounces
what is cleaner called? CRC MAF cleaner
where can i get it? any auto store?
Old Oct 19, 2006 | 10:12 PM
Nexx's Avatar
Nexx
been there and done that. i just sprayed everything. let it dry for a few hours. put everything back together. nothing broken.
Old Nov 12, 2006 | 07:22 PM
blksnake's Avatar
blksnake
CRC MAF Cleaning instructions here
Originally Posted by derek173
Old Nov 12, 2006 | 07:30 PM
brooke's Avatar
brooke
Just buy some electrical contact cleaner from Home depot.. I have done mine twice now and no problems..
brooke
Old Nov 5, 2009 | 07:13 PM
Frequency 3.5.0's Avatar
Frequency 3.5.0
just tried the crc maf cleaner tonight and the result was pretty good.. the power flow feel more smoother and pulls noticeably stronger around 2.5-3k rpm... i was skeptical about it at first but now i'm glad i tried it... i have 04 with 55k miles on it..
Old Nov 6, 2009 | 07:00 AM
cheshirecat79's Avatar
cheshirecat79
Damn your engine has a high redline.
Old Nov 6, 2009 | 05:10 PM
Frequency 3.5.0
lol, mine's one of kind
Old Mar 24, 2011 | 07:26 AM
jubes's Avatar
jubes
Can anyone point out on the pictures given which parts should be sprayed?
Old Mar 24, 2011 | 09:29 AM
  #38
amr_electron's Avatar
amr_electron
Just spray directly,
Old Mar 31, 2012 | 04:41 PM
  #39
P3rcoc3T's Avatar
P3rcoc3T
I tried cleaning my sensor and now I'm getting p0113 and p0102 . Any tips? Ill keep looking places and trying to figure it out.
The car runs like **** now wont go over 2k dies the first 2 times you try to start.
Old Mar 31, 2012 | 05:41 PM
  #40
P3rcoc3T's Avatar
P3rcoc3T
Well... I am a idiot ... I had installed a new filter, piping and I ended up putting the sensor backwards so it was getting no air flow. Fixed the codes. Car runs wayyy better. Cleaning with crc works wonders.
