Steering/drifting to the right-tried everything, HELP!
Old Jul 11, 2006 | 02:45 PM
350drft's Avatar
350drft
Default Steering/drifting to the right-tried everything, HELP!
Basically, the cars steers to to right, so I need to overcorrect the steering wheel to the left to go straight. Below is what the dealership has tried already, PLEASE, any other ideas?!
1) Allignment (2 different shops)
2) Different wheels
3) Different tires
4) Replace front right strut/housing
5) Replace front right suspension copmpression rod.
6) Replace steering knuckle
7) Adjusted steering rack
8) Removed sway bars
9) Took measurements to see if anything in the suspension was bent.
10) Reset steering angle sensor.
What else can we do? The dealership says they're out of ideas, and the keep calling Headquarters and not getting anywhere. What should I do?
Old Jul 11, 2006 | 02:57 PM
showstoppertk's Avatar
showstoppertk
lemon law it man.
Old Jul 11, 2006 | 04:44 PM
Mazinger Z's Avatar
Mazinger Z
wtf...yea i smell lemon lime
Old Jul 11, 2006 | 06:04 PM
350drft's Avatar
350drft
I bought it from the dealership a year ago, plus I have a bunch of mods on it(none of which have anything to do with the steering issue), Plus, this only started happening 3-4 monthes ago. What can I still do? As crazy as it sounds, am I entitled to revert the car back to stock and get a new one from the dealer at no extra cost to me? BTW my car is an '03. HELP!
Old Jul 11, 2006 | 06:26 PM
eat rice z33's Avatar
eat rice z33
ok you wouldnt happen to have an aftermarket LSD do you?
Old Jul 12, 2006 | 12:38 PM
350drft's Avatar
350drft
Nope, stock Track model VLSD in there. Could this be affecting it? I've doe a small share of drifting and auto-xing.
Old Jul 12, 2006 | 01:42 PM
Fluid1's Avatar
Fluid1
Drive in the left lane. The crowned road will help you out.
Old Jul 12, 2006 | 02:10 PM
BlackZero6's Avatar
BlackZero6
are you sure it isnt following road crown? or is it a really bad pull?
Old Jul 13, 2006 | 05:29 PM
350drft's Avatar
350drft
Haha, definatly not the road crown. I wish the pull was that minimal! The dealership has my car as we speak. I have my fingers crossed.
Old Jul 13, 2006 | 07:50 PM
Fluid1's Avatar
Fluid1
Good luck. My car's still at the dealer, been there since Sunday night.
Old Jul 17, 2006 | 10:24 PM
350drft's Avatar
350drft
FIXED!!!!!!!!!! Dealership took the car down the street to some "old timers" who apparently are real nasty with alignments. Car rides like a dream.
Old Jul 18, 2006 | 07:07 AM
Fluid1's Avatar
Fluid1
It was just an alignment issue? Did they add anything, or just use a digital system?
Old Jul 18, 2006 | 08:36 AM
Asterix's Avatar
Asterix
Mine did the same thing. The dealer just tweaked the steering wheel center, and didn't seem inclined to fix anything, so I took the car to a shop that I trusted to give me a good alignment. Turns out the thrust angle was off by a wee bit because the rear toe wasn't symmetrical. Sure, everything was within tolerance, but it still pulled. Once the thrust angle was set to 0 by a competent shop, no more pulling for me.
Don't get an alignment at a dealer; go for the independent shop that runs race cars. They'll understand the need for accuracy.
Asterix
Old Jul 21, 2006 | 10:19 AM
jhagan's Avatar
jhagan
There is a service bulltin on this the dealer doesnt talk about. Se the dealer.
Old Jul 21, 2006 | 11:01 AM
al503's Avatar
al503
you might also check the tire pressures and see if the right side isn't overinflated compared to the left tires.
Old Jul 31, 2006 | 11:45 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
2) Different wheels
3) Different tires
350drft, I've only just found this thread. I have major issues with my 350 at the moment, just curious as to what the problem was with your 350???
