Spark!!!!!
Old Jul 19, 2006 | 06:49 PM
tecni's Avatar
tecni
Default Spark!!!!!
I just put my engine back in the car after I already had it running. I had to pull it again because I forgot to RTV the rear timing cover to the heads and they began to leak like crazy. Now I'm trying to start the car up again and I got:
AIR
FUEL (aeromotive FPR @ 20psi)
SPARK????
I kept cranking the motor and I wasn't getting any combustion.
I pulled a coil out and hooked up a spark plug to it, held it against the block to ground it and tried cranking it again to see if I could get a spark but I didn't.
What could be causing this to happen?
I checked my fueses and everything seemed well.
anyone???
Old Jul 20, 2006 | 11:39 AM
tecni's Avatar
tecni
amazing... 46 views and not a single comment.
Old Jul 20, 2006 | 12:23 PM
97supratt's Avatar
97supratt
I would check your crank sensor, ignition module or box, ecu, any check engine codes? Do you have a diagnostic tool?
Old Jul 20, 2006 | 12:24 PM
97supratt's Avatar
97supratt
Did you make sure to plug everything in? Maybe you forgot to plug in a crank or cam sensor.
Old Jul 23, 2006 | 04:01 PM
tecni's Avatar
tecni
I did double check everything but my crank sensor might have been damaged during the engine build. I will check and if necesary replace it.
Thanks for the reply bro!
Dr.Paulyy
Jul 29, 2019 07:45 AM
RyansZ33
Sep 15, 2015 05:54 AM
PhiTauZ
Nov 9, 2005 12:49 PM
