A 5000 mile oil change interval...
Old Sep 28, 2006 | 10:49 AM
boma's Avatar
boma
It's about the money...
Old Sep 28, 2006 | 10:50 AM
boma's Avatar
boma
Culture too. Europe is known for having a driving culture. The average person doesn't eat food and talk on the cell when they drive. The average person may know more about cars than over here. That might play a factor on when they are told to change their oil.
Old Sep 29, 2006 | 06:15 AM
TheProfessional's Avatar
TheProfessional
I just got my lab analysis today, they suggest running the next oil setup for 6,500mi.
Old Sep 29, 2006 | 08:04 AM
davidf's Avatar
davidf
5000 mile changes is even fine for the nonsynthetic if driven in a normal manner.
Old Sep 30, 2006 | 08:43 PM
corsair's Avatar
corsair
Originally Posted by Wired 24/7
That's a great track record... I see your point but as long as I'm monitoring oil analysis along the way, I'll know whether I need to change the oil more frequently than I am. It's better to analyze and know rather than guess and assume. You were playing it safe by using synth for only 4400 miles, which is probably the best option, but also the most costly.
Plus I plan to switch to synthetic once the oil stops showing breakin.
I wouldn't necessairly believe and trust all of the info you get from your UOA's. I thought they were a great idea at the time I was doing them. They always came back looking great, until Nissan told me I needed a new engine. Then all the UOA hype went out the window.
Just my .02
Old Sep 30, 2006 | 08:48 PM
corsair's Avatar
corsair
+1
It's sickening to think about how much oil is wasted in this country. We've been programmed to buy into the 3K/3MO OCI.
Old Sep 30, 2006 | 08:56 PM
boma's Avatar
boma
The factory service manual says we can change at 3,750 miles.
Old Sep 30, 2006 | 08:57 PM
boma's Avatar
boma
Just my .02
So you messed up your engine from waiting until 5K to change your oil instead of 3K? How far did you without an oil change? Please give us some more details. (Not trying to bash).
Old Sep 30, 2006 | 11:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Just my .02
Without explicit details, how am I supposed to take this post?
I have no idea what caused your engine's problem, let alone what that problem might have been.
I'm not talking down to you, but unless you provide some background here and some concrete evidence that an overextended oil change interval caused your problem, I'll still be doing as I please with regards to OCI and UOA...
Old Sep 30, 2006 | 11:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
More details on your car please, year, miles, etc ??
Fuel in the oil, does not sound good.
I'm wondering if it has to do with using synth...
Old Nov 25, 2006 | 10:24 AM
TheProfessional
2006 base, miles at change was 15k, current as of 11/26/06 were 18k. All are highway miles, never redline.
I think I screwed up with my sample, I forgot to extract from the middle of the oil draw, I took the first 4 ounces of oil from the bottom of the pan which they say do not do. But I wanted to know if there were any metal traces found primarily. That is probably why there was fuel in the oil.
Old Feb 24, 2007 | 11:06 AM
TheProfessional
Default Update for Blackstone analysis from 9/29/06
I submitted a sample for analysis the end of January with 7,350mi on the change with RP 10W-30 and a K&N oil filter and this was the POSITIVE result:
Attached Thumbnails A 5000 mile oil change interval...-020507-blackstone-results.jpg
Old Feb 26, 2007 | 10:56 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
looks like your engine is breaking in very nicely
Old Feb 28, 2007 | 06:27 AM
gothchick's Avatar
gothchick
What is the break-in schedule for a new Z? The dealer told me that new engines these days don't need to be broken in like they used to. I have an '06 with about 500 miles on it so far. Since the '06's are known for oil consumption issues, I wanna make sure I break it in correctly. Thanks! :-)
Old Feb 28, 2007 | 10:49 AM
Bevo's Avatar
Bevo
From your owners manual, it says for the first 1,200 miles dont go over 4k rpm
Old Feb 28, 2007 | 07:24 PM
918 Z's Avatar
918 Z
what is a UOA?
and where can i have this test done on the oil?
Old Mar 1, 2007 | 10:39 AM
TheProfessional
Oil Analysis, $20 base, $30 including a TBN (additive index)
http://www.blackstone-labs.com/
Old Mar 1, 2007 | 01:23 PM
  #38
918 Z's Avatar
918 Z
thanks
Old Mar 2, 2007 | 12:38 AM
  #39
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
There is a lot of controversy with how people should break in.
But, if you follow the owner's manual suggestion, you should be fine.
Old Apr 30, 2007 | 06:55 PM
  #40
TheProfessional
Yet another 5,000 mile + oil change with a positive result. See UOA below.
Attached Thumbnails A 5000 mile oil change interval...-blackstone-042907.jpg
