Stalling!!!! Need Opinions..
Well after 20k miles on my aps tt setup I'm now having stalling issues. From a dead stop and reving the motor it will not do it but under load while driving and coming to a stop it dies or almost dies. So far I have replaced the spark plugs, installed new belts since they were very worn with cracks, cleaned the MAF with cfr eletrical spray, reset the ecu,checked the BOV, checked for a vacuum leaks and have yet to fix the problem.. My only other guess would be a bad 02 sensor or maybe even a bad MAF.. Any help would be greatly needed..
Thanks,
brooke
Thanks,
brooke
is there someone you can swap MAF's with to see if makes a difference?
i don't think an 02 sensor will cause you to stall. my guess is either the MAF or vacuum leak... which you've check already.
From past experience this could be several things. It is very hard to say, what is because i do not know exatly what the car is doing. The best advice I can give you, is take the car to a mechanic/tuner ASAP. I would hat for you to hurt the car more by delaying necessary matience.
