Cooling System Service 60K miles
Old Sep 23, 2006 | 08:46 AM
boma's Avatar
boma
Default Cooling System Service 60K miles
I have a coupon at Firestone for a cooling system service for $39.99
It includes
-Inspect cooling system and pressure test for leaks
-Flush system
-Refill with correct amount of recycled coolant
-add sealant/lubricant
What do you guys think? This is a really great price; do you think this particular service is ok for my '03 350Z?
Old Sep 23, 2006 | 02:43 PM
rotaryrocket7's Avatar
rotaryrocket7
I wouldn't recommend using recycled coolant, why not spend the extra 15 bucks or whatever it costs to have new coolant put in. I'm also not a fan of using the pressure method of coolant flushing. If they over-pressurize the system you'll blow gaskets which can cost plently to fix. And the sealant lubricant doesn't sound like a good idea either, although I'm not exactly sure what they mean by that (I'm assuming something like Bar's Leak or other type "quick-fix").
Why not just drain it yourself, it's pretty easy...
Old Sep 23, 2006 | 03:08 PM
This is the first I have about recycled coolant. How much can a gallon of new coolant cost anyway?
Old Sep 23, 2006 | 03:13 PM
boma's Avatar
boma
The cooling system change seems pretty involved you have to remove three drain bolts on the engine block and replace O rings. Has anyone tried this?
Old Sep 26, 2006 | 03:27 PM
Zquicksilver's Avatar
Zquicksilver
I've drained my radiator 3 times, it's not hard, but sometimes getting the air out of the system is a pain!! Now a complete drain seems to be a PITA, besides being very messy. For that I plan on letting somone else service it and letting it drain all over their garage floor.
Zquicksilver
Old Sep 29, 2006 | 02:29 PM
NCPG's Avatar
NCPG
I think I would spend the extra $ and let the dealer service the cooling system. I have had bad experiences with Firestone.
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
SharX59
Sep 30, 2015 10:54 AM
