noise when accelerating on a 06
Old Nov 5, 2006 | 10:43 PM
Cho_Z's Avatar
Cho_Z
Default noise when accelerating on a 06
hey guys i have a 06 350z with 7,xxx miles on it. Recently my car started to make i guess a rattling noise when im accelerating between 2,500-3,000 rpm and right when i shift. its most audible in 1st, 2nd, and 3rd, and somewhat audible in 4th. Its really noticeable when i drive for the first 10 minutes, and then isnt as loud after. It seems like its coming from the front, maybe tranny? im not sure, if you guys have any ideas i would really appreciate it. thanks
Old Nov 6, 2006 | 01:43 AM
type7's Avatar
type7
My 06 has the similar noise, but mine happens below 3000 rpm in 1st and 2nd gear only. Not exactly sure why, but I am guessing just some pannel rattles.
Old Nov 6, 2006 | 06:18 AM
z-u-later's Avatar
z-u-later
Do you have any mods? Sometimes mods will introduce new sounds to your Z.
Old Nov 6, 2006 | 09:55 AM
Cho_Z's Avatar
Cho_Z
no its stock, no mods at all. im going to check today to see if i can find whats rattling
Old Nov 6, 2006 | 10:06 AM
350zex's Avatar
350zex
I would check your oil. The 06's have a problem with burning oil, and mine was doing something very similar to that when I found it was dangerously low on oil. Has your oil light been popping up on sharp turns any?
Old Nov 6, 2006 | 11:14 AM
91ZCpe's Avatar
91ZCpe
I noticed that noise to on my dads Z, when we're accelerating. I was thinking it could be the rear axle clicking?
Old Nov 6, 2006 | 11:29 AM
CLMZ's Avatar
CLMZ
Is it a definitive rattle of parts.... or a ping of sorts? If it's the later, you could be hearing a gas ping.
Old Nov 6, 2006 | 12:48 PM
jtabraham's Avatar
jtabraham
when you go to get it checked out, make sure you ride with the mechanic so you can point out the sound you're talking about
Old Nov 6, 2006 | 01:15 PM
Cho_Z's Avatar
Cho_Z
im sure its not the rear axle clicking. its coming from the front. as for gas i always put in premium 91 octane at chevron and dont think is a gas ping. can you tell me how a gas ping may sound? i think it may be the oil i havent seen the oil light come on yet. but im going to change out my oil and see if thats the cause, im about due for one. thanks for all the input guys
Old Nov 6, 2006 | 01:17 PM
Cho_Z's Avatar
Cho_Z
also the oil pressure levels seem to be lower than usual. would that be caused by low oil levels?
Old Nov 6, 2006 | 02:24 PM
matman99's Avatar
matman99
Is it a tinny, metalic sounding rattle? I had that sound on my Altima and it was a loose heat shield. I actually have the same sound now after I got my headers installed. I'm thinking they didn't tighten something up properly. Possilby a heat shield again. Maybe something loosened up in your car. Have a mechanic go for a ride with you so they can hear it.
BTW severe ping sounds like you have pop rocks in your engine, other people say it sounds like rocks being shaken in a jar. I had that problem after I got some bad gas and dyno'd it, when I hit about 6K the engine sounded terrible. But you shouldn't get it too much at lower rpms, detonation (pinging) from bad gas or low octane fuel is usually a higher rpm issue. At least as I've been told.
Old Nov 6, 2006 | 02:28 PM
mavtais's Avatar
mavtais
You're probably talking about the 2500-3000 rpm rattle from the aluminum shift bushing. It's normal. Almost any car with aluminum shift bushing will rattle at a specific rpm range.
You accelerate in 1, 2, or 3, and go past 3000 rpm, then just let off (do not push in clutch). You'll hear it for sure. It's normal.
Old Nov 6, 2006 | 09:47 PM
Cho_Z's Avatar
Cho_Z
im not sure its normal its really loud and noticable, i dropped it off at the dealer to have them check it out to be safe
Old Nov 7, 2006 | 06:57 AM
On Nightfall's Avatar
On Nightfall
x2 on my 06. I figured it was normal.
Old Nov 7, 2006 | 07:16 AM
zpwnzu's Avatar
zpwnzu
I have it on my 06 - its confirmed engine pinging - there is apparently an acceptable "amount" of pinging. im taking it back for them to fix it properly. That and im burning more oil than saddam in the first iraq war.
Old Nov 7, 2006 | 08:37 AM
Combat350z's Avatar
Combat350z
Saddaam didn't burn any oil in the the Gulf War it was all a conspiracy by the republicans
Lol jk I'm a republican and liked GW senior
Old Nov 7, 2006 | 08:50 AM
Alang35's Avatar
Alang35
maybe the flywheel rattle?
Old Nov 7, 2006 | 08:55 AM
Combat350z's Avatar
Combat350z
That or maybe the strut bar is loose and is rattling against the hood when you're shifting
Old Nov 9, 2006 | 12:47 PM
240Zplus110's Avatar
240Zplus110
Add my name to the list.
The sound definitely is coming from the engine bay and it does sound like valve rattle or pinging. Mine occurs usually when the engine is warm and I'm under load (up a hill or heavy acceleration). I've had the dealer investigate and so far they say they cannot duplicate the noise.
On the other issue... I've just started my second round of oil consumption tests. First round showed about 1 qt in 4000 miles - they say it needs to be more than 1 qt for 3000 mi before it is considered excessive.
Old Nov 9, 2006 | 06:13 PM
whitehotz's Avatar
whitehotz
I have a 06 and I have been to the dealer several times about the pinging which started shortly after I bought it 4 months ago( see my original post by whitehotz). Dealer has replaced the anti knock sensor, and the ecm unit and it is still pinging, usually on acceleration at about 2500 to 3000 rpm. I have on engine mods, and always run 92 octane gas, and from different sources. Getting very frustrated with my performance car that sounds like an old Vega.
