highway speed rear end vibration
Old Nov 16, 2006 | 10:17 AM
nathanwl2004's Avatar
nathanwl2004
Default highway speed rear end vibration
I was wondering whether or not anyone else has had this problem
occasionally when I am cruisin at highway speed, the rear end of the car will start to vibrate. it will start out as low hum, and barely noticable, it will get worse until the point it's like a wump, wump wump kinda sound and it will vibrate the whole car pretty bad. the weird thing though is that it goes away whenever I stop or slow down to a near total stop. does anyone know what this is? does it sound like it might be the diff for some reason or something.
does it sound like something that might be covered under the power train warranty.
Old Nov 16, 2006 | 10:22 AM
chimmike's Avatar
chimmike
1) check your lug nuts
2) Check your tire pressure
Old Nov 16, 2006 | 10:24 AM
thirty5ounces's Avatar
thirty5ounces
maybe you slung weights of your rim and they need balanced
check your tire pressure
check your lug nuts
my guesss is they need balanced
Old Nov 16, 2006 | 10:30 AM
deviljon's Avatar
deviljon
i think something like this happened to me before. i was going about 75 and heard a humming noise, and as it faded away the whole car jolted. it happened 2-3 times but my foot was steady on the throttle.
One thing i remember was that my car was low on oil (oil consumption problem) during that time . After I added about 2 quarts, the sound never came back. Anyone else have this problem before?
Old Nov 16, 2006 | 10:31 AM
nathanwl2004
thanks guys I'll do try that
I just can't figure out why it only does it some times and then it just goes away.
I mean I can be goin at 60 and it will do it. as soon as I stop it will go away and then I can go right back up to 60 and no problem for days.
I'll try what you guys said and see if it helps. thanks
Old Nov 16, 2006 | 10:41 AM
gqong's Avatar
gqong
check the lugs or wheels...sounds like that would be the cause if it is coming at high speeds. balance/retightenin of lugs/ etc.
Old Nov 16, 2006 | 10:43 AM
Jenn350Z's Avatar
Jenn350Z
Check tires for damage or loose belts
Old Nov 16, 2006 | 10:44 AM
LAKERSFAN's Avatar
LAKERSFAN
"I mean I can be goin at 60 and it will do it. as soon as I stop it will go away and then I can go right back up to 60 and no problem for days. "
It doesnt sound like a tire balance issue if this is the case. if the tires were unbalanced, then the vibrating wouldnt just go away for a couple days, right?
Old Nov 16, 2006 | 01:06 PM
HighwaySpeed's Avatar
HighwaySpeed
Exclamation
No, my rear end does not vibrate.
Old Nov 16, 2006 | 01:23 PM
imjdoggie's Avatar
imjdoggie
drive shaft, tranny???
Old Nov 17, 2006 | 06:11 PM
thirty5ounces
if its a minor balancing issue you wont feel effect untill higher speeds,,,thats why when you stop it goes away...get your fing tires balanced and you will be fine, its not your lugs if they were that loose you would have lost a wheel by now.....
Old Nov 21, 2006 | 02:55 PM
nathanwl2004
alright bud then tell me this, why then can I be doing 60 mph for 30 minutes straight and all of a sudden it will happen with no change in speed what so ever. as soon as I stop it goes away. and then when I start going again I can go straight back to 60 or even higher with out it coming back for days.
if the tires weren't balanced properly than it should theoretically be repeatable and it would come back every single time that I hit a certain speed. however it doesn't come back every single time I hit a certain speed. some times it will some times it won't.
once it starts it will also continue to occure until I come to a near complete stop; including speeds much lower (ie: 25-30 MPH) than when it originally started.
Old Nov 21, 2006 | 03:21 PM
Eazzy's Avatar
Eazzy
Keep in mind Belt Separation in a tire----It will do weird things. A good Balance Machine will tell the story. A GOOD tire man can just run his hand over it and tell.
hulkout
Apr 28, 2017 09:00 PM
pr_350z
Oct 1, 2015 05:03 PM
