my Z is pulling to the right!! help please!
I have the same problem. On my 2004 coupe, I had the problem with stock setup. After hotchkis springs installed and an alignment, problem went away.
My current 2005 roadster again has the same problem with stock setup and now I am lowered on s tech springs and this time the alignment didn't fix the problem. I am lost and confused.
Guess I have to learn to live with it. I just had the alignment yesterday and saw the spec sheet on the alignment.
Tony
Tony
Originally Posted by Eazzzzzzy
+1 --Agreed, Take it to a Hotshot, Most regular alignment guys dont know they're a$$ from a hole in the ground
I had mine to 7 In SA tx. til I found a wizard in Austin. 30 minutes and $90.00 it was perfect
^^^ where is this "WIZARD" I would like to see his magic on my Zed..
Crap, I have the same problem with my Roadster. I have to track the car a little to the left to keep it going straight. The oem tires look like crap compared to the other tires on the market. Looks like I'll try some lowering springs, new tires, and an alignment and see what's up.
Mine always has, since the day it came off the truck. Now i am perfectly aligned running nismo wheels + pilots sports, these things didnt even take a weight at the alignment shop and it still tracks to the right, get used to it!
