Driver's Side Speaker not Working...HELP!
need some help from the audio gurus....my drivers side speaker gets all garbled out when i switch to cd...but when using the radio the speaker works fine....i have the stock bose unit...just wondering if anyone had any input on possible troubleshooting...i already tried different cds just to make sure it wasnt the cd...
i had the same issue early this year & when i took it to the dealer they found it's not the speaker it's the stereo itself need to be changed so they changed it under warranty
so if your car is not under warranty i would advise you to have an after market part because the stock unit cost around $1600
Originally Posted by capeland
I also have the same issue!
yeah It's the oem radio is having that problem but what can I do my warranty is just went out
it's time to get new aftermarket radio for me
so i decided before going to the stealership i would take things apart and inspect it myself...i took apart the front dash area and took a look at all the wires going into the bose hu...they are actually under a lot of stress and are pulled very tightly to the drivers side direction of the car...i simply gave the wires some stack and pushed the wires tightly back into where they connect with the hu and problem gone...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
