Flashing PSI indicator
Old Mar 24, 2003 | 07:17 PM
stuart735's Avatar
stuart735
Question Flashing PSI indicator
Is there a way to turn the flashing psi indicator and warning light off? Due to this morning's cold termperature my tire pressure apparently went under the limit so the alarm went off. The day warmed up, and the tire pressure is where it started (about 32 psi on the computer) but the lights won't go off. What do I do? This is only my third day with the car ......
Anybody know?
Old Mar 24, 2003 | 11:06 PM
spn350z's Avatar
spn350z
Default Re: Flashing PSI indicator
Anybody know?
The pressuew is still too low, check center console door for correct PSI. Once you inflate to that PSI light should go off.
Old Mar 25, 2003 | 09:48 AM
darrensi's Avatar
darrensi
Even when you get the pressure up to the recommended rating the PSI light won't actually go off until you drive the car a short distance - a few hundred yards should do it.
Old Mar 25, 2003 | 10:17 AM
stuart735's Avatar
stuart735
Thanks -- I picked up a pressure gauge and I'll top off the tires after work, and see what happens.
apex locator
Jul 23, 2021 02:27 AM
Depravity
Oct 1, 2015 04:49 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
hardwood66
Sep 8, 2015 04:31 AM
