My fix for the lack of a hatch pop inside the cabin...
Old Mar 25, 2003 | 11:44 AM
WebToker's Avatar
WebToker
Default My fix for the lack of a hatch pop inside the cabin...
Installed a aftermarket alarm :-) I can now pop the hatch from my remote while the car is on.
Old Mar 25, 2003 | 11:58 AM
3rdpower's Avatar
3rdpower
Um... your frob does already this??
Old Mar 25, 2003 | 12:02 PM
WebToker's Avatar
WebToker
Not while the car is turned on.
Old Mar 25, 2003 | 06:24 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Do you really NEED to pop the hatch with the car turned on? If it IS turned on, odds are pretty good that the keys (and the Fob) will be right there with you in the ignition.
Old Mar 25, 2003 | 07:19 PM
Canadian350Z's Avatar
Canadian350Z
If you need to pop the hatch I'm gonna guess you, or someone, is by the back of the car... why not use the button by the licence plate?
Old Mar 25, 2003 | 08:04 PM
marcZZZ's Avatar
marcZZZ
not a regular pain in the ass
Isn't there a place on /under the stabilizer bar in the back hatch area that opens the hatch without being in back, with the car on, without the fob? I seem to remember something about that the day I picked up my car.
Old Mar 26, 2003 | 03:11 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yes, there is a pull out wire type thing that is by the strut bar that does that.
Old Mar 26, 2003 | 09:39 AM
WebToker's Avatar
WebToker
Have you ever tried to use that? It will almost slice your finger not to mention it is a pain in the *** to reach back there.
Old Apr 8, 2003 | 09:50 PM
sevnn's Avatar
sevnn
Webtoker,
Any reputable car audio/alarm installation company should be able to interface either an internal button to the hatch pop selenoid or install a second aftermarket selenoid and wire that to a button.
Old Apr 9, 2003 | 07:00 PM
rouxeny's Avatar
rouxeny
Actually, I think this is a glaring error in the Z. I have frequently had to pop the trunk while the key was still in the ignition with the engine on. Let's say you drop your friend off and he has to get his bag from the back, or recently when I went to Foxwoods and the security guard wanted to check the contents of the trunk. I had to either stop the car and push the button, or get out of the car and hit the license plate button. For those unfamiliar with that button (everybody but Z drivers), they'll never figure it out.
Annoying....
Old Apr 9, 2003 | 08:12 PM
Swisha350z's Avatar
Swisha350z
I hate that feature on teh Z. It is an annoyance having to take the key out of the ignition to pop the hatch. The release under the strut bar doesnt release when the cars on either.
Old Apr 10, 2003 | 08:10 AM
WebToker's Avatar
WebToker
Originally posted by sevnn
Webtoker,
No **** :P
Old Apr 10, 2003 | 08:33 AM
sevnn's Avatar
sevnn
Or perhaps you could read mine?
an internal button
My point was that you could have an internal button release put inside of the car WITHOUT having to install a full blown alarm system. It would be cheaper and would not have to deal with the hassle of a full alarm system. It could also be integrated into a factory style button near the VDC turnoff or by the heated seats switches.
Old Apr 10, 2003 | 08:48 AM
WebToker's Avatar
WebToker
I like that idea. Although I was going to have the alarm installed anyways. But this is something for others to think about. Maybe Nissan will come out with it for the 2004 and we can just add it
Old Apr 10, 2003 | 09:46 AM
sevnn's Avatar
sevnn
For the time being I'm quite happy with the factory Nissan alarm. I'll probably look for a multicar option in the future for my fiance's Maxima and my Z.
I was noticing while popping the hatch that the button is not mechanical, it is electrical. With that in mind, it would be pretty easy (i'm betting) to tie in a switch directly to the trigger wire coming from that switch. The other option would be to find the trigger wire coming from the factory alarm (probably in behind the right kick panel) and tie to it. Even though the factory alarm release does not work while the key is on, the trigger wire would most likely still work if signalled individually.
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
