Torque Wrenches
Old Dec 23, 2006 | 02:37 AM
TayTaythatsme04's Avatar
TayTaythatsme04
Default Torque Wrenches
Hey Guys,
Need to repair and install a few things and I deleted my old thread about this so, whats everyones opinion on a good torque wrench (need ft pounds) ?
and I have another torque wrench currently, but I left it set . Is it possible if I leave it back set at 0 for a while the spring will loosen back to normal ?
Thanks
T
Old Dec 23, 2006 | 03:35 AM
Eazzy's Avatar
Eazzy
Craftman makes a reasonably priced wrench and easy to replace if u have probs with it. Personally I wouldnt be very conserned about the wrench u want to bring back to Zero.
I may get flamed but after using them for 35+ yrs I know a little. Torque is not mystifying. A couple Lbs off is not crucial, main thing is, for example with head bolts or Mains or Rods is consistancy through out the sequence.--Balance.
Keep in mind that a Head bolt is not torqued to X amount of FtLbs because it is a head bolt. Its torqued to X amount of FtLbs because it is a particular size and Grade of Head Bolt. And that is the torque that that Bolt is designed to take.
Old Dec 23, 2006 | 05:25 AM
DavesZ#3's Avatar
DavesZ#3
Yeap, get a Craftsman - they go on sale pretty regularly and you can pick them up for $50 to $60 depending on the sale.
Once deformed, the spring is not going to go back on it's own. A least not without some heat treatment or other process. It would be cheaper to buy a new one than to fix the old one.
Old Dec 23, 2006 | 07:55 AM
Sean's Avatar
Sean
if you want to check your wrench, look for a PMEL in your area and see if you can make a friend to test it
here are places that are hiring, stands to reason you could get cheched if you live near one.
http://www.pmel.org/Jobs.htm
StateNuke08
Oct 31, 2015 05:01 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
RWDBajan
Sep 17, 2015 04:52 PM
raceboy
Jan 15, 2003 10:18 PM
