Engine problem?
Old Feb 20, 2007 | 06:22 PM
SHIFT_Lore's Avatar
SHIFT_Lore
Default Engine problem?
So, i just got my 350z tonight. Its a 2004 manual with 36,000 miles. I was driving it tonight when all of a sudden it kind of "stopped revving". I would push the pedal in all the way and the rpms would go up VERY slowly, almost not at all. I turned the car off, and back on, and it worked fine. Also, "Serivce engine soon" light came on . Whats wrong = (
edit: Im reading about NVIS and other devices used to cut power on our engine. I have a mobil speedpass + mercedez benz key on the same key ring. Could this have caused the problem? But then why would the engine light still be on?
Old Feb 22, 2007 | 07:07 AM
imjdoggie's Avatar
imjdoggie
Check your MAF sensor
Old Feb 22, 2007 | 07:14 AM
Bobbo756's Avatar
Bobbo756
maybe check vacuum lines also
Old Feb 22, 2007 | 07:39 AM
THE TECH's Avatar
THE TECH
Check the CEL and let us know. Could be anything.
Old Feb 23, 2007 | 12:25 PM
sumfknguy's Avatar
sumfknguy
ok.. try this.. My car threw a CEL yesterday on the way home from work.. it started running like schit in the mid to upper rpm's... i immediately dropped her off at the dealer as its under warranty...
I get a call today and was greeted with laughter... my freakin fuel cap wasn't tight and it caused a vacuum leak... so yeah, go make sure your gas cap is snug.. meanwhile.. I will continue to feel like a dumb ***.
Old Feb 23, 2007 | 02:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
your car went into limp mode, and you should go get that CEL checked ASAP, it's not going to go away.
take it to autozone to check CEL for free. pep boys tried to charge me $20 once
Old Feb 25, 2007 | 10:19 AM
SHIFT_Lore's Avatar
SHIFT_Lore
After this happened, i unplugged my batery for 10 minutes, and the CEL went off. I took it to a dealer and the service manager told me it was not limp mode, but most likely my throttle chamber, w/e the fk that is. Anyways, the code the ECU should have recieved ( they need a code to replace any part) was not in the ECU. So, she told me the car should run fine, but if it ever happense again not to reset the battery and bring it straight in.
Thanks for info guys.
Old May 30, 2007 | 07:26 PM
Moroccan_Mole's Avatar
Moroccan_Mole
did you ever get this figured out?
this happened to me today. almost the exact same thing. the car revs very very slowly after about 3500 rpm. however there is no CEL
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
