Tire Pressure Monitor Acting Up
It started yesterday. Went off because I had 29 lbs in my left rear. So on my way home from work, I checked all my tires and filled them up to 34 lbs. The damn light has yet to turn off and it still says that all of my tires are around 30 PSI? Is it just because the weather in Dallas has been jacking us around going from 80s over the weekend to 30s in the mornings now? I know cold air is more dense, but I'm hoping this will go away when it warms up.
I can't hear any kind of leak on any of my tires, so I'm a little annoyed but a little worried. Any words of wisdom to share?
Originally posted by 350zSpeedRacer
Good grief! I thought we weren't supposed to go over 35 PSI. Oh well. Thanks, Brad!
Originally posted by droidekaus
You should be heating up to around 37-38 PSI in normal driving and 39-40 in more spirited driving.
For some reason, and I'm getting it checked out soon, my sensors read 28-31 psi when 2 different tire guages read the pressure at 35-37 psi. I think it's just a calibration problem.
There is a reason the tire says 51 PSI max pressure on the side-wall. Because THAT is the pressure you're not supposed to go over.
As others said, 35 PSI is target cold pressure. I regularly get 40 PSI on my long highway drive home.
At the race track, when I was there a couple weeks ago, I was seeing max hot pressures hitting 46 to 47 PSI. I was driving VERY hard. I dropped the pressure in the tire to around 44~45 hot. The next morning I checked my cold pressure and it was UNDER 35. Had to put air back in them.
same happened to me the other day...night it got pretty nippy so in the am the sensor went off.. had to up the pressure to 40 for the light to go off....been fine ever since.
Anyone have any wear problems with the rear RE040's?
My rears have worn as if they have been over inflated. My cold tire pressure has hovered around 35 +/-1psi on avg. I have almost 20k miles and the tires need to be replaces. The thing that annoys me is that the reason they need to be replaced is just the center portion. The rest of the tire is fine for several more thousand miles.
Oh well....
Sorry to 'jack your thread Christi.
D
Oh well....
D
articfury,
same here my rear tires started show added wear in the middle and I reduced the pressure in the rear tires to 33.5psi cold. Rear of car is not as heavy as front, that's my reason to the wear.
D
D
D'oh!
