how to adjust clutch pedal?
Old Apr 14, 2003 | 04:13 AM
jesseenglish's Avatar
jesseenglish
Default how to adjust clutch pedal?
I'd like to change the distance I need to push the clutch down and release to have the clutch disengage/engage. Anyone have a procedure on how to do this? I've got to push the pedal almost to the floor before I can shift or gears grind.
Old Apr 14, 2003 | 05:23 AM
VandyZ's Avatar
VandyZ
It is hydraulic so I don’t know what you can do with it. I do know that once you disconnect and bleed it it feels different but I don’t know how that will accomplish what you want. I do know my clutch engages about half way. It was at the bottom at first. After a month or so it went to middle and has been there ever since.
Old Apr 14, 2003 | 07:10 AM
aelius's Avatar
aelius
As was mentioned, the clutch cannot be adjusted. It engages a bit too close to the floor for my taste, as well, but apparently nothing can be done about it.
(My wife's new Civic is even worse. The clutch has to be depressed so far that it sometimes is difficult to start the car.)
Old Apr 14, 2003 | 01:37 PM
Desmo's Avatar
Desmo
The service manual details the procedure for adjusting the clutch pedal. Mainly it just gives the stock specs for freeplay, clutch engagement height, and interlock switch position, and tells you how to adjust the pedal into spec. But there might be some leeway built in that allows you to set the engagement point somewhere closer to your liking.
PM me and I'll try to explain the procedure.
Desmo
Old May 10, 2003 | 07:37 PM
ttheisen93's Avatar
ttheisen93
Vandy,
I had the same experience; close to the floor at first, and now about halfway. I'm usually very kind to my transmissions and haven't had to ever get a new clutch, so I was kind of worried I had done something wrong to get that big a difference in a few months. Glad to hear its normal.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
