ACT Clutch & Prolite Flywheel Install
Old Mar 30, 2007 | 10:37 AM
quint1's Avatar
quint1
Default ACT Clutch & Prolite Flywheel Install
Installed an ACT clutch and Prolite flywheel. After driving about 50 miles, the check engine light, TCS Off and slip light came on and will not go out. I took it to the dealer, they said the ECU does not recognize the new flywheel and is falsely reporting. Has anyone had this problem after an install? Is there an easy fix?
Old Mar 30, 2007 | 10:45 AM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Never had this problem but I know those all come on if you've worn out your brake pads as well
Old Apr 2, 2007 | 01:01 PM
97supratt's Avatar
97supratt
I have the ACT street disc clutch and prolite flywheel and the check engine light didn't come on. Why don't you check it with a OBDII scanner.
Old Apr 4, 2007 | 07:57 PM
quint1's Avatar
quint1
Thanks to those of you who responded. Here are the results of testing. I took my Z to the folks at AAM in Gaithersburg, MD. This is what they found.
- PO355 CKP sensor light problem
- C1130 Engine 1 fuel cut system faul-
- Transmission mount bolt (finger loose)
- Bellhousing bolts loose
- Several knicks on flywheel crank trigger wheel, throwing off ignition pattern
- Excess grease found on throwout bearing and all over flywheel
- Lots of clutch dust in bellhousing and flywheel
- Drill marks on pressue plate
- Shifter plate misaligned, 5th and 6th gear alignment off
What a mess . I will never take my car to a NISSAN dealer again for an aftermarket install. I'm gonna do everything possible to get my labor dollars back from the NISSAN dealer.
Many thanks to the guys at Altered Atmosphere, particularly (Frank) for putting my Z back in top operating condition. You guys really made me a believer (customer for life).
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
