AC problem ... help
Old Apr 14, 2007 | 05:45 AM
nightcrawler_8's Avatar
nightcrawler_8
Default AC problem ... help
hi there guys.. i dotn knwo if am facing a problem or this is normal.. please help .. check the attached pics for the info...
thanks
Old Apr 14, 2007 | 05:52 AM
Sean's Avatar
Sean
it is normal, high humidity where you are.
Old Apr 14, 2007 | 05:59 AM
nightcrawler_8
yeah its too much humed but i looks like the Z is pissing in her panties... hahhaha .. my buddy z didnt **** that much as mine...
Old Apr 14, 2007 | 06:01 AM
Eazzy's Avatar
Eazzy
It is very normal as said with Hi Humidity locations. As a matter of fact, it is showing that your condenser drain is free from all the crap that accumulates within the fins and the enclosure. < good thing !!!! An A/C unit is in essence, also a dehumidifier, the higher the humidity, the more water from air is removed, hence----Draining from your unit
Old Apr 14, 2007 | 06:03 AM
Sean's Avatar
Sean
touch it, smell it, if it's just water you know it's ok.
Old Apr 14, 2007 | 06:04 AM
Eazzy's Avatar
Eazzy
And if he is running his at the same setting, then he needs to find out 1.) Is his drain becomeing plugged ? 2.) Is his A/C unit running top efficiency
Old Apr 14, 2007 | 06:17 AM
nightcrawler_8
thaanks guys .. appreciate the reply.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
