!!!Urget Help NEEDED!
Old Apr 19, 2007 | 07:49 AM
importxracerxr's Avatar
importxracerxr
Default !!!Urget Help NEEDED!
hi everyone i disconnected my battery last nite hoping to reset my ecu. i woke up and went and pluged it back in and started the car and everything was working cept everything had been reset. As i approach my driveway i turned off my engine but i decided to repark my car so i turn on the engine and it turned on but all of a sudden it dies. the rpm meter just falls to 0. i tried several times to turn on but same results so i decided to slightly tap my foot on the gas pedal before ignition and start it up and i get this loud VROOOOMMMM!! and the car was on and ready to run so i turned it off again hoping that solved it but no luck the engine jus dies after it starts ...pplllzz help i really need the car soon class startting sooonnn...!!!
Old Apr 19, 2007 | 07:57 AM
bofa's Avatar
bofa
Did you check the battery cable to make sure it's tight?
Old Apr 19, 2007 | 08:03 AM
importxracerxr
yeah its tight alrite i wrenched it in there. ..
Old Apr 19, 2007 | 08:09 AM
gqong's Avatar
gqong
never heard of this issue...any way you can have the dealership check it out? but be sure to replace whatever isnt oem before they give you the runaround!
Old Apr 19, 2007 | 08:15 AM
zeekle's Avatar
zeekle
why were you trying to reset the ECU?
Old Apr 19, 2007 | 08:28 AM
blackstealthz's Avatar
blackstealthz
Well if its not the cables i would contact the dealership.This sounds like one of those small problems that can cause a big pile of
Old Apr 19, 2007 | 09:09 AM
THE TECH's Avatar
THE TECH
Could try jumping it. Maybe it is a battery issue.
Old Apr 19, 2007 | 09:16 AM
alfonsohaskins's Avatar
alfonsohaskins
something like that happen to me alson but a lil different i was getting my system installed and i guess the losers who installed it left my car on and it drained my battery well we thought if we just chargerd the battery back up it would be ok but it still didnt work even after putting in a new battery i had it towed to nissan and turns out the the ecu was messed up how i dont know but it was still under warranty and they fixed it for free it was just a pain in my a** dealing with everything
Old Apr 19, 2007 | 10:10 AM
andypandy's Avatar
andypandy
did the car stumble before it died? since the ecu has been reset, try the throttle repositioning thingymajig. might help with the idle so the car doesn't stumble and die.
Old Apr 19, 2007 | 12:41 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Perhaps try throttle position re-learning procedure
http://www.technosquareinc.com/350reset.htm
Old Apr 19, 2007 | 11:05 PM
importxracerxr
well i think the engine only shuts down when the engine is warm...any one with any solutions?
Old Apr 20, 2007 | 06:29 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
In case you haven't noticed, idle RPM drops a bit when the engine is warm compared to when you first turn it on. did you try my suggestion or did you just assume it wouldn't work?
Old Apr 20, 2007 | 09:35 PM
maximumsportZ's Avatar
maximumsportZ
+1.
My car use to do this, even dying when coming to a stop after I did that reset it helped out alot.
Old Apr 21, 2007 | 11:43 PM
importxracerxr
thnx guys ill give it a try now!! ill update results
Old Apr 24, 2007 | 06:27 PM
BallZdeepNYC's Avatar
BallZdeepNYC
i wonder if doing this will help with the sputtering my car does (seems to have a low idle)
Old Jun 14, 2007 | 06:08 PM
bizcotch's Avatar
bizcotch
It actually worked!!! i disconected my battery for a couple of hours to change the Cam sensor, then afterwards, was having the stall issue. I tried the resetting method and it worked.
Old Jun 15, 2007 | 05:19 PM
UTexas EE's Avatar
UTexas EE
I'm having similar problems after replacing the battery on my '03. It starts up from cold then if I stop and start it again it will start up then shut off. Takes another time or two to actually have it go into idle and stay on, but each time it struggles.
I never got the CEL after replacing the battery. Should I reset the ECU and try the re-learning procedure anyway?
Sorry for my super low post count and asking silly questions. I registered awhile ago but have never had a single problem with my Z (bought it used with like 20k miles) till now. Been very happy with it.
Old Jun 15, 2007 | 06:16 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If your car is stalling out when warm,
do the intake air learning procedure and/or throttle position learning procedure (not sure which one is the most important) which is linked in this thread...you should be good to go...
others have suggested cleaning the throttle body using carburetor cleaner
Old Jun 15, 2007 | 08:02 PM
UTexas EE's Avatar
UTexas EE
Ok. Gonna try it out this weekend and see how it goes. Thanks much for the help!
Old Jun 16, 2007 | 08:27 PM
UTexas EE's Avatar
UTexas EE
I guess I don't fully understand the Idle Air Volume Learning procedure from technosquare. Step 8 says to fully depress the accelerator pedal for 20 sec. Won't that hurt the engine? I started to do that but it took it to redline right away.
And does this have to be done with the ECU reset?
