2 questions
Old Apr 22, 2007 | 06:33 PM
FAIRLADYZBABE's Avatar
FAIRLADYZBABE
Default 2 questions
does anyone else have a problem with certain gas pumps??
i get it almost 1/2 way full and the pump wants to click off and keeps doing it, have to hold the nozzel part way out and pump it super slow.
i also want to know what kind of oil people use, how many use syntethic.
Thanks
Old Apr 22, 2007 | 07:55 PM
bacalhau16's Avatar
bacalhau16
Never had that problem with the Z myself.
I use regular 10w-30. Have not switched to synthetic and probably wont, unless I ever get to go F/I.
Old Apr 22, 2007 | 08:34 PM
I don't know what year your 350Z is, but check the appropriate service bulletins for gas filling problems.
Old Apr 23, 2007 | 10:51 AM
VO...'s Avatar
VO...
Administrator
Thanks
I only see one question.
The answer is no.
Old Apr 23, 2007 | 10:57 AM
Bevo's Avatar
Bevo
I have no problem with gas pump.
For engine oil, I use Mobil 1 5W-30
Old Apr 23, 2007 | 03:02 PM
FAIRLADYZBABE
2006
and thanks i did find an older post about this problem, so before the repost police get me, i apologize for not searching first.
Old Apr 23, 2007 | 03:56 PM
ZCARBANDIT's Avatar
ZCARBANDIT
no prob w/pump gas either
and i use Motul 5w-40 syn
Old Apr 23, 2007 | 09:06 PM
roast's Avatar
roast
Had tons of problems with pumps shutting off early. Had the TSB addressed and it fixed the (very common) problem.
I also use the recommended dino oil as suggested in the owners manual.
Old Apr 23, 2007 | 09:43 PM
Ztalker's Avatar
Ztalker
i went to this new Chevron station and one of their pumps was acting up like that.... never had any problem filling up at costcos or Arco stations. i just leave the pump hooked up and it tops out by itself.
Old Apr 23, 2007 | 09:45 PM
ldawg32's Avatar
ldawg32
i have that problem and i just go to the same pump everytime. one pump works fine and the one next to it doesnt. very wierd
Old Apr 23, 2007 | 09:46 PM
MyFairladyZ2006's Avatar
MyFairladyZ2006
You fill your own gas?
Just get full service
Old Apr 24, 2007 | 06:50 PM
FAIRLADYZBABE
to be honest i dont know where a station around here that even has full service anymore
Old Apr 25, 2007 | 05:57 AM
HondaKiller's Avatar
HondaKiller
your re-fueler hose has cracks in it and causing pressure to build up. Once the pressure is built up the gas doesnt flow into the tank quick enough so it seems like it is full. Extensive labor for just a damn hose, but it will do the trick and shouldnt cost you a thing. (recall)
I use 5-30 Royal Purple Synthetic
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
