I need revised Alignment Specs - 2003 18" Wheels
Old Apr 23, 2007 | 11:52 AM
VandyZ's Avatar
VandyZ
Default I need revised Alignment Specs - 2003 18" Wheels
Just as the title says . . .I need the revised Alignment specs that reduce the feathering. After my last alignment, it has gotten worse again so I just want to make sure I have the correct numbers for the shop incase they are using the originals.
Thanks in advance!
Bout ready to slap on wagon wheels if this piece does not quiet down.
Old Apr 23, 2007 | 01:42 PM
infamous350's Avatar
infamous350
come on someone reply with answer i need thsoe specs also
Old Apr 23, 2007 | 02:22 PM
DavesZ#3's Avatar
DavesZ#3
The TSB on the feathering problem lists the preferred Toe as 2mm. You can view the TSB here....
http://www.nissanhelp.com/Ownership/.../NTB04-043.htm
Attached Thumbnails I need revised Alignment Specs - 2003 18" Wheels-fsusnap.jpg   I need revised Alignment Specs - 2003 18" Wheels-rsusnap.jpg
Old Apr 25, 2007 | 11:32 AM
infamous350
that link isnt working it shows nothin were else can i find it thnx
Old Apr 25, 2007 | 02:07 PM
DavesZ#3's Avatar
DavesZ#3
The link is to the TSB and it works fine for me (both at home and work).
All you need is in the two pics I also posted.
Old Apr 28, 2007 | 11:16 AM
infamous350
thnx for your help gunna go align to these specs see if it fixes the problem
Old Apr 28, 2007 | 04:33 PM
tmak26b's Avatar
tmak26b
Isnt the feathering related to an issue with the suspension? My 04 never had it
Old Apr 28, 2007 | 05:56 PM
DavesZ#3's Avatar
DavesZ#3
Nope. It was caused by mis-alignment. My 04 did have it.
Old Sep 8, 2007 | 10:38 AM
darklocust's Avatar
darklocust
Finally found the alignment spec sheet. I was hitting my head when I couldn't find it in the manual.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
