passager window???
Old Jun 17, 2007 | 10:30 AM
BojanC350z's Avatar
BojanC350z
Default passager window???
so yesturday im sitting in my house on the copmuter finishing up some stuff and outside all of a sudden it starts pouring rain...a few seconds later i remembrd that i didnt close my windows...i run outside to close them, i pull both the buttons at the same time so they roll up. the drivers window rolld up with no problem and so did the passager one.. a few seconds later the passager window rolls down maybe 1/4 way down...i close it , a few seconds later it does the same thing... after a few tries when i rolled the window up i shut the car off so that it had no power to roll back down... i turn on the car later when i go to work and the window was working properly... anyone know what the problem might be? or has it happend to anyone else?
Old Jun 17, 2007 | 10:34 AM
SSZVirginia's Avatar
SSZVirginia
The window motor needs to be replaced. Same thing happened to me.
Old Jun 17, 2007 | 10:37 AM
JonnyRod's Avatar
JonnyRod
it probably doent need to be replaced...just adjusted. my passenger window did the same thing. the window is trying to go up too far, hitting the top, and then doing its 'auto-reverse' function. just take it to the dealer. ad if its not under warranty...take your door panel off for them...itll save you $90. then theyll only charge you like 30 min. for resetting it
Old Jun 17, 2007 | 11:09 AM
Jenn350Z's Avatar
Jenn350Z
Or don't use the auto-roll up. Just pull up on the button just a bit until it closes.
Old Jun 17, 2007 | 11:14 AM
PM-Performance's Avatar
PM-Performance
one of my bimmers did that that had no frames on the windows. Usually means there is an obstruction of some sort so it rolls part way back down.
Old Jun 17, 2007 | 11:18 AM
Shift_Z33's Avatar
Shift_Z33
I had the same problem w/ my driver side. Only when using the auto-up feature does it go back down. I just had to get it reset and she's good to go
Old Jun 17, 2007 | 07:38 PM
flintgauge's Avatar
flintgauge
well my driver window is beating my passenger window up by about 1.5 to 2 seconds... it's kinda starting to worry me.
Old Jun 20, 2007 | 01:14 PM
Escobar's Avatar
Escobar
its probally on its way out. Does anyone know the best way to get the window to burp?
Old Jun 4, 2009 | 11:56 AM
geminipov2's Avatar
geminipov2
I am having the same problem, someone posted a way to reset the window without having to take it in, but I can't find it now that I need it.
Does anyone know the trick to reseting the window? I have a 03 350Z.
Old Jun 4, 2009 | 12:10 PM
ag4670's Avatar
ag4670
lol well some reason i cant post anything on the forum with 350z tech just type reset 350z window in google and it should be the first web page
Old Jun 4, 2009 | 12:56 PM
geminipov2's Avatar
geminipov2
thank you I'm going to try this asap!!
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
AP350z223
Sep 8, 2015 04:38 PM
