throttle body..
Old Jun 26, 2007 | 07:52 PM
steppinrazor's Avatar
steppinrazor
Default throttle body..
if a throttle body is out of sync how would that be fixed... i recently put in a new intake manifold and am having some issues, im thinking we could have messed with the throttle body... any one know how to fix that?
Old Jun 26, 2007 | 08:53 PM
sahib's Avatar
sahib
my friend had some issues with his 04 g35c, he went to the dealer and got it replace becuz it was under a recall or sumthin, it take slike 10mins if you knw what ur doing...take it to the dealer...
Old Jun 26, 2007 | 10:04 PM
DJMatrix1067's Avatar
DJMatrix1067
use the search function. i've read about this a few times before.
steppinrazor
even if i have mods? i thought that voided the warenty
Old Jun 26, 2007 | 11:25 PM
steppinrazor
i tried already, i found a bunch of stuff dealin with throttle bodys but nothin dealing with it bein outta sync..
Old Jun 26, 2007 | 11:27 PM
blasian's Avatar
blasian
What do you mean out of sync?
Have you tried resetting the ECU?
http://www.technosquareinc.com/350reset.htm
Old Jun 26, 2007 | 11:33 PM
steppinrazor
i was told before installing my intake manifold to be very careful with the throttle body, that if it was slightly off it would really f*ck with my car.. when i told some one some of the problems that i was havin after the instilation they said that it sounded like something with my throttle body was out of sync or that i had a vacuum leak
i tried that webcite but my check engine light is not on so would it still be beneficial?
Old Jun 27, 2007 | 03:32 AM
SpeedRcr's Avatar
SpeedRcr
you touched the butterfly valve in the throttle body didnt you??? just make sure its all tightened down and do a idle position reset and along with the ecu reset...
Old Jun 27, 2007 | 05:10 AM
Kolia's Avatar
Kolia
Find that vacuum leak if you have one!
Old Jun 27, 2007 | 07:24 AM
steppinrazor
how do you find a vacuum leak??
Old Jun 27, 2007 | 07:28 AM
steppinrazor
i think so... i accidently pushed that little thing that moves inside it, it was on accident and i tried to move it backm so it couldnt be to far off i dont think..
Old Jun 27, 2007 | 09:50 AM
Kolia's Avatar
Kolia
You can gently spray some propane gas around the intake manifold and listen for an idle speed change.
Or you a open end stetoscope to listen around the intake.
Old Jun 27, 2007 | 11:40 PM
steppinrazor
an idle speed change.. and if i do find one where do i go from there??
Old Jun 28, 2007 | 03:23 AM
Kolia's Avatar
Kolia
You fix it!
Bad gasket or simple unpluged hose, just adjust/replace the part...
Old Jun 28, 2007 | 05:31 AM
steppinrazor
thanks alot, im going to try that out.. any idea on fing the throttle body if thats the problem, or does it not seem thats the problem
pslamp32
Feb 8, 2017 09:07 AM
Darkspy
Sep 7, 2015 09:09 PM
