Window supposed to be like this?
Old Jun 29, 2007 | 04:02 AM
bigbosstwo40's Avatar
bigbosstwo40
Default Window supposed to be like this?
When I pull the window switch up for the driver's side it goes up all the way then comes back down about 4 inches. It always happens when i click it up into auto mode. Even does it sometimes when I hold it in the whole time. I don't know if it's a problem or if there is something I need to switch. It's not really a problem but more of an annoyance. Just wondering if this is normal. Thanks everyone.
Old Jun 29, 2007 | 04:12 AM
Billhyco's Avatar
Billhyco
nope, take back to dealer for them to adjust it. its going up to far and the window motors thinks something is stuck between the window and the door hence it coming back down.
Old Jun 29, 2007 | 04:45 AM
bigbosstwo40
crap, alright thanks for the help
Old Jun 29, 2007 | 05:40 AM
SSZVirginia's Avatar
SSZVirginia
They replaced my window motor when this occured. I am happy to hear it can be adjusted...
Old Jun 29, 2007 | 05:44 AM
Billhyco's Avatar
Billhyco
it might not be able to be adjusted. i think there is a way to re-time it, but its been to long for me to remember the specifics.
Old Jun 29, 2007 | 06:03 AM
ickysz's Avatar
ickysz
well damn, I thought that was normal, it does it to mine as well.. but not when I keep a hold on the up switch, once it goes all the way up, i let go & its fine, but if I click up for auto mode & let go, it comes back down 4 inches..
Old Jun 29, 2007 | 06:05 AM
PerfZ's Avatar
PerfZ
Can be "reprogrammed" but you have to pull the inside of the door. Dealer charged me $40 to do it - it's only covered as an "adjustment" 12/12,000. This was a year ago and it is occasionally doing it again. Annoying, but it is NOT a bad motor.
Old Jun 29, 2007 | 06:15 AM
zdotcom's Avatar
zdotcom
I just had mine reset. Takes less than an hour at the dealership. Mine also would go down when I closed the door right after the window "zips up".
Old Jun 29, 2007 | 06:30 AM
bigbosstwo40
^^^ mine does that as well. I almost got screwed the other day because I put the window up and it stayed up. then I shut the door and it must have come down. well an hour later it started pouring rain and I realized that my window was down those couple inches. I dont have a warranty on any electronic's so I'll just put up with it for now until all my bills run through and the dealer can pull forty bucks out of my butt. Does anyone know what causes the timing to be thrown off?
Old Jun 29, 2007 | 09:23 AM
FleckDZ's Avatar
FleckDZ
mine just started doing this yesterday. i have an extended warranty i bought with the car. hopefully its covered and i dont have to fork over $40.
Old Jun 29, 2007 | 09:36 AM
KenZee's Avatar
KenZee
The auto up mechanism has to account for someones arm, hand, head, etc. being in the path of the window and it has to reverse the windows direction before injuring whatever is in its way. It sense this by pressure in some way and in my opinion that is what changes slightly over time and needs to be adjusted. You know both windows are operated each and every time you open the door, so they get a lot more use than in a regular car. If you have access to shop manuals, the procedure is pretty clear. I don't have access to mine right now, but I have seen the adjustment steps spelled out before on this site. Just do a search...
Old Jun 29, 2007 | 09:50 AM
Malikot's Avatar
Malikot
Rice Rocket
Mine just started doing this yesterday and my warranty just ended. Can I take it to the dealership and just fork over $40?
Old Sep 10, 2007 | 07:59 AM
sibble's Avatar
sibble
Anyone know how to adjust this properly?
I'd like to do it myself, my driver-side window is starting to do it. It only does it once in a while. I think I might try pushing up on the weather stripping and see if that does anything.
Old Sep 10, 2007 | 11:35 AM
usmanasif's Avatar
usmanasif
There are many threads on the window adjustment here. There is also a TSB on this on another Z forum with directions on how to reset the motor; very simple process once you have the door trim off.
Siqcology
Sep 18, 2019 01:45 PM
hulkout
Apr 28, 2017 09:00 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
