Should I go ahead with the Bose amp TSB fix?
Old May 6, 2003 | 11:25 PM
s9am_me's Avatar
s9am_me
Default Should I go ahead with the Bose amp TSB fix?
from the searches.. half said it worked better.. but the other half says they've lost bass control. Has anyone done the Bose amp TSB fix recently? Can you give me a review of the new amp? Also, the 0.99 fix seems to work only with the newer amps. haven't tried it yet tho.
Old May 7, 2003 | 08:03 AM
zwindsor's Avatar
zwindsor
Twisty addict
I had mine replaced about a month ago. Generally it is better then the constant booming that occured all the time. The deep bass as been reduced but you can crank it up if you're into that kind of listening.
Since you got your car in December are you sure you fall into the TSB parameters?
Also what's this 0.99 fix you mentioned?
Old May 7, 2003 | 09:01 PM
s9am_me's Avatar
s9am_me
0.99 Bose Fix
yes my car does fall into that category. I'm getting the same symtoms of volume adjusting by itself.. ect.. my car was manufactured on 9/2002 BTW.
Old May 8, 2003 | 07:44 AM
zwindsor's Avatar
zwindsor
Twisty addict
Thanks for the link. I'm not really into Audio mods so I don't view that forum. Interesting findings though.
Old May 8, 2003 | 12:42 PM
slaponte's Avatar
slaponte
I have done both.
The TSB gets you an amp that is programmed differently. Before the TSB I could not hear the radio at all. After, you can hear it (bass is reduced), but you also loose some power and the stupid volume up-down (pilot thing) keeps driving you nuts.
The 0.99 fix gets the volume pilot to stay put, thus letting you adjust your volume and not having it go up down and everywhere. It might have an effect on tone, but I personally can't notice it much.
Neither is a perfect solution. But I think the solution will be another amp or reprogram of your amp, so having the TSB amp won't matter.
Old May 8, 2003 | 03:57 PM
s9am_me's Avatar
s9am_me
so you think i shouldn't waste my time with the TSB then?? I have $0.99 to spare so I might just try that instead.
Uriyo_
Sep 8, 2021 08:46 AM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
