MAF Sensor and Engine Sensor 1, HELP??
Old Jul 19, 2007 | 08:15 AM
azrlee's Avatar
azrlee
Default MAF Sensor and Engine Sensor 1, HELP??
Hi guys!!
Yesterday while driving to my home in a stop sign the idle of my car went to aprx 665rpm and a Check Engine light came out, 3 seconds later the VDC OFF and Slip sign came on too, I turn the car off and on and then only the CEL keep coming on, took the car today to the dealer, connected a diagnostic ECU on it and it came with this answers:
MAF sensor circuit (P0102) Code:2
Engine Sensor 1 (C1130) Code:7
They told me to leave the car because it was unsafe to use it and they will come back to me possible on the next week, andy help guys trying to understand what`s happending with my Z????
Old Jul 19, 2007 | 04:14 PM
andrew538's Avatar
andrew538
Samething happen 2 me before, idle doesn't go over 2,400 rpm!
do u have cold air intake, if u do, check the mass air flow senser c if is clean, or connect right on the intake...
did u mess with the wires on the ecu, it might be weak circuit/ bad wiring... I have to take the wires apart and reconnect it because of a wiring failure of S-AFCII.
I hope ur car is still under warranty, or is gonna cost a fortune... I hate dealer... Good luck man...
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
