trouble!
Old Jul 27, 2007 | 05:03 PM
kihun's Avatar
kihun
Default trouble!
ok.. I'm at work.. I drove car for two hours straight and parked. At dinner time, I turned on my car and guess what? It cranks two times and it turns on.. I'm here thinking.. uh... wtf? why is it having so hard time to crank?.. so I turn it off.. and turn it on again to hear the sound.. and now.. it try to crank and won't.. After thinking, I borrowed the jump cable and jumped the car.. now it turns on without a problem.. How long do I have to running the car to recharge the battery? and what might cause the problem to drain the battery? I didn't turn on anything on the car.. and I believe this is brand new battery..
Old Jul 27, 2007 | 05:17 PM
flintgauge's Avatar
flintgauge
you believe, or you know? Did you check the battery?
Old Jul 27, 2007 | 05:20 PM
DavesZ#3's Avatar
DavesZ#3
Either weak battery or dying starter. Take it to Autozone and they can test both for you.
Old Jul 27, 2007 | 05:24 PM
Corradoslc7's Avatar
Corradoslc7
Has your battery ever been changed or is it original? It may be time for a new one.
Old Jul 27, 2007 | 09:09 PM
kihun's Avatar
kihun
I just bought the car. They are new I think, or at least almost new. I just jumped the car and it starts and run. I have the engine code on but I have no clue. It's battery for sure. Look like it's charging. Let see how it works tomorrow morning.
Old Jul 27, 2007 | 09:35 PM
kihun's Avatar
kihun
it look like it's alternator problem.. it's not charging the battery.. how much do they charge? does it cover under the warranty?
Old Jul 28, 2007 | 05:50 AM
DavesZ#3's Avatar
DavesZ#3
If you have a 2003, it's been out of [factory] warranty for a while. Do you have an extended warranty? Does it cover the electrical system (a lot only cover mechanical problems)?
Old Jul 28, 2007 | 06:39 AM
kihun's Avatar
kihun
I have extended warranty... does it cover?
Old Jul 28, 2007 | 06:54 AM
KPierson's Avatar
KPierson
You probably just left something on. One dead battery isn't anything to be concerned about. It's when the battery will only sit for 2-3 days that you need to be concerned.
It isn't typical of a car to start up, drive fine for two hours, and then not start up. Are you positive you didn't leave the headlights on?
Old Jul 28, 2007 | 07:00 AM
fairladyz47597's Avatar
fairladyz47597
this problem is going to take you awhile to fix. they usually fix about five things before they find the problem. good luck and try not to get too frustrated.
Old Jul 28, 2007 | 08:46 AM
DavesZ#3's Avatar
DavesZ#3
It depends, there are different companies that offer them and there are different levels of coverage.
Old Jul 30, 2007 | 04:35 PM
blinkygab's Avatar
blinkygab
deleted
pslamp32
Feb 8, 2017 09:07 AM
onefastdoc
Jan 22, 2003 04:25 PM
ares
Oct 30, 2002 02:49 PM
