rough idle
Old May 12, 2003 | 06:31 AM
zperfect's Avatar
zperfect
Unhappy rough idle
Question? Has anyone had problems with the idle in neutral running rough?
i have noticed when i'm just sitting at idle the rpm's go below 750 and the car seems to spudder. anyone else have a problem like this? is my idle to low?
only had car three weeks. i did put on the
CAI/grounding kit . i don't believe it could be that. right? help
Old May 12, 2003 | 07:14 AM
jelledge's Avatar
jelledge
Default Rough Idle
Another person had this problem some time back and took their car to the dealer. Turned out to be a misfiring injector and had it replaced.
Take it in and have them check it out.
slay2k's Avatar
slay2k
I get the same every now and then.
They're like that from factory.. I think some tuning done locally on the fuel/air ratio will solve the problem, perhaps.
Old May 12, 2003 | 07:24 AM
zperfect's Avatar
zperfect
Default rough idle
thanks for yor quick responses.
i'm on the phone with the dealer now
making appt's for idle/window streaks/
rim defect... caio for now
Old May 12, 2003 | 02:18 PM
lew f's Avatar
lew f
I have not had the problem as yet
Old May 12, 2003 | 07:17 PM
frenzee's Avatar
frenzee
I had the same exact problem from day 1. I was starting to suspect worn valves, leaky guides, grounding and what not.
Took it to the dealer, said my idle was set too low by 100rpm, reset it to 750. Rough idling is completely gone now. But I also swapped out the fluids with Redline at the same time, so I can't be sure if what the dealer did was what cured it, but now idle is now pegged at 750 with no sign of sputter whatsoever. Hope this helps.
Old May 13, 2003 | 09:15 AM
zperfect's Avatar
zperfect
Default rough idle
Thanks yes that does help i will get them to look at it. then will be changing to redline soooon.........
liqalu04
Jan 2, 2022 12:58 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Darkspy
Sep 7, 2015 09:09 PM
