HELP! cars not going past 1500rpm
Ive been on vacation for 1 1/2 month and just got back today. I started up my car and noticed my Z isnt going past 1500rpm. The fuel would just cut when i try to past 1500 and would be like that when driving. I tried reseting the ECU and clean the MAF.
Had this happen to me. Scared the **** outta me. All I did is pulled over and let my car kool down 4 like 30 mins, then a couple weeks later tranny blew?? idk if thats what it was but no probs now Knock Knock(knocking on wood
Originally Posted by blueper4mancez
did you tried to adjust rev limit yet ?
The best thing to do is this.
First check to make sure you have oil.
Then turn on the car and let it get to normal operating temps, let it warm up completely before revving. You can cause damage by revving when its not warmed up.
Once its warm and you rev it, and it doesn't rev past 1500 it could be a number of things. Check to see if your check engine light is on. If it isn't check to see if your air filter is clogged, check your MAF, check to see if you have gas in your car, these may sound dumb but its the norm.
I just got home to the same issue, I was gone for a little over 2 weeks. I let the car idle for about 10 min and when I went to hit the gas a bit no power. I turned the car on and off a few times now it's fine, but the CEL is on. Im going to go back now and check everything out. I don't want to hear anything about exploding tranny's thanks.
Ended up being some issue with the throttle. I was away on vacation for a couple weeks and the car just sat in the car port (had some bad weather). Did the ecu reflash and the light is off car is running like a champ. I have to schedule an oil change with Nissan later this week so I'll have them take a look to make sure all is well.
etkms
Jun 19, 2022 06:30 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
