Argh!! Snapped head off some bolt, how do I ...
Old Oct 2, 2007 | 04:51 PM
imntcrzy's Avatar
imntcrzy
Default Argh!! Snapped head off some bolt, how do I ...
get them out.
I was putting back on the door plate that holds up the window track and motor, yes I was dealing with the dreaded dying/now dead window motor. As I was tightening it up with my 1/4" ratchet and before I knew it I snapped one of the 10mm bolts.... before I knew it again I snapped 2 more. I thought I was only tightening a quarter turn after hand tightened but who know.
Can you someone advise me on how to remove the headless bolts?
Old Oct 3, 2007 | 05:18 AM
JG 350Z's Avatar
JG 350Z
You need to drill a small hole and use a screw extractor. At first I thought you snapped cylinder head bolt!
Old Oct 3, 2007 | 02:01 PM
Sean's Avatar
Sean
the brand known as Easy-out is good.
Directions
http://homerepair.about.com/od/inter..._extractor.htm
I find Titanium tipped bits work well for the starter hole.
Old Oct 3, 2007 | 02:03 PM
bbs350z's Avatar
bbs350z
good info^^
Old Oct 4, 2007 | 05:56 AM
imntcrzy's Avatar
imntcrzy
appreciate it guys!
Old Oct 4, 2007 | 06:46 AM
PDX_Racer's Avatar
PDX_Racer
Next time, use a torque wrench. According to the FSM, they're only supposed to be tightened to 35 in-lbs. That isn't a lot!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
