rear clicking noise
Old Oct 12, 2007 | 07:09 PM
MR350's Avatar
MR350
Default rear clicking noise
i drive an 05 enthusiast with 14k+ miles. sometimes if i coast slowly, and come to a stop I will hear a rear clicking noise, AFTER coming to a halt. This doesnt happen when I am going at higher speeds.
could this be the axel or rear suspension? any help? thanks
Old Oct 12, 2007 | 07:16 PM
ZCARBANDIT's Avatar
ZCARBANDIT
probably the rear axle click syndrom.mine has started to get it as well.o well time to take the half shafts out and replace the bolts.
Old Oct 12, 2007 | 08:15 PM
MagicPie's Avatar
MagicPie
its common, mines been doing if for over 35K miles and I was just under my car to check a few things out and noticed nothing of concern.
Its just the bolts clanking, with no real problem and its merely an annoyance.
I do believe there is a TSB for it, but all they do is slap some grease on there. They may replace something, I dont really know, but someone told me it just came back again, shortly after they fixed it.
Old Oct 13, 2007 | 06:54 AM
ZCARBANDIT's Avatar
ZCARBANDIT
Yeah, there is a tsb.Grease the half-shafts and then replace the flange bolts.
Old Oct 13, 2007 | 01:26 PM
Al_s14's Avatar
Al_s14
its not the bolts that cause the noise, only reason Nissan tells to replace those bolts is because they are aluminum and they want no liability if they brake after being removed and over torqued too many times. An actual fix is applying PBC grease(Nissan Anti-Sieze) to the axle splines and any area where it contacts the bearing/hub.
Old Oct 15, 2007 | 07:05 AM
MR350's Avatar
MR350
once i re-grease the axel is the clicking noise going to come back?
Old Oct 15, 2007 | 07:19 AM
OldManZ350's Avatar
OldManZ350
Who has the link to the TSP?
Old Oct 15, 2007 | 07:23 AM
iStan's Avatar
iStan
ZR
TIMROD PM sent
Old Oct 15, 2007 | 08:35 AM
Al_s14's Avatar
Al_s14
eventually but not any time soon.
ajcool2's Avatar
ajcool2
Thought I was the only one with this problem.
Old Oct 25, 2007 | 08:39 AM
kingklay's Avatar
kingklay
oh no your not! i have it too and its frickin annoying.
time to try suggested fixes.
Old Oct 25, 2007 | 03:47 PM
Al_s14's Avatar
Al_s14
lol i cant believe you guys are bothered THAT much by it. picky ***** ey
Old Oct 29, 2007 | 05:17 PM
huligan1475's Avatar
huligan1475
AAHHH so that's what that is. I had taken it to get it repaired, and about 5 months, 7154 miles later...it's back. I've grown to live with it. One of these days I'll jack up the rear end and take care of the problem...when it becomes a problem.
Old Oct 30, 2007 | 05:27 PM
The rear axle cannot click after the car is stopped. Nothing inside the axle is moving.
Old Nov 2, 2007 | 01:33 PM
You are welcome.
Old Nov 7, 2007 | 05:56 AM
fabre80's Avatar
fabre80
Sorry to post in this old thread but i believe i have the same problem,lol, can anyone give me the link to this problem and what to do?
Old Nov 7, 2007 | 06:59 AM
Road Warrior's Avatar
Road Warrior
tsb will take care of it...have not had the problem since...just take it to the dealer and they should know what to do
Old Nov 7, 2007 | 01:39 PM
Al_s14's Avatar
Al_s14
are you telling me that out of all those replies you could not get an answer...if so you may have reading comprehension problems buddy
Old Nov 9, 2007 | 01:22 AM
toguedrifter's Avatar
toguedrifter
I recently had the same issues... ANNOYING! I still had 24,000 mi on my 05 base, so I took it to a near by dealer and they changed to nutz/bolts etc. problem fixed!
Old Nov 13, 2007 | 04:14 PM
Will_Evo's Avatar
Will_Evo
Just to 3rd or 4 th what everyone is saying, I took my Z into the dealer and they are fixing it the way the TSB? I guess thats what its called says to. Nissan replaces the bolts first and greases everything up...IF it keeps clicking(which it doesn't) then they actually replace something major, not sure what it was the guy said, but yea its free so just go to nissan and tell them there is a rear axle clicking noise and they will know exactly what your talkin about.
Oh and while your there might as well check for recalls...I guess there was a fuel hose assembly recall on mine? Dunno i let em do it though, it was free
