window and lock problem
Old Oct 25, 2007 | 02:38 PM
wckdclw's Avatar
wckdclw
Angry window and lock problem
hey, whenever i try to lock or unlock my car from the button on the doorpanel nothing happens. and when i try to roll the windows down, the driver side one wil go down but not up and the passenger side window doesnt do anything at all. any thought on what the problem could be? The only way i can roll the windows up is by using the key in the lock.
Old Oct 25, 2007 | 04:13 PM
wckdclw's Avatar
wckdclw
bump...
Old Oct 26, 2007 | 05:20 PM
Al_s14's Avatar
Al_s14
it sounds like master switch is bad. does pass window work if you use pass door switch?
Old Oct 27, 2007 | 10:38 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Samething happend to me. I went to my dealer and they replaced the motor on the passanger side window. So I would thing it has something to do with a switch gone bad, or the motor is just starting to show sighns of dying.
Old Oct 29, 2007 | 02:32 AM
Sk8fe's Avatar
Sk8fe
Man, what's going on here?!!! Yesterday, my passenger side window goes down and then later decides its not going back up again! Arg! Driver's side window works. Both driver's side and passenger door lock buttons work; however, both Driver's side and pasenger side window buttons for the passenger window do nothing and I can hear a clicking sound coming from the passenger door???
Any idea?
Did your guy's door lock button work on the side you had the problem? Are both windows on the same fuse?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
