shifting to 5th gear wont work..help!!
Old May 30, 2003 | 06:43 PM
beckymbowie's Avatar
beckymbowie
Default shifting to 5th gear wont work..help!!
dont know if anyone has this problem..car has about 8 k miles on it now...drove for an hour then shifted into 5th gear and it wont let in..the rev went up to 4 k rpm instantly..so i had to get into 6th gear....will changing the fluid help or should i let the dealer look into thi??
pls help me ...any advise will do..
Old May 30, 2003 | 07:17 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Go to nearest dealer.
Old May 31, 2003 | 10:11 AM
ricks350z's Avatar
ricks350z
cant anyone help her..comon all u techs out there...or has anyone had this problem at all
Old Jun 2, 2003 | 01:33 PM
Desmo's Avatar
Desmo
My car does this sometimes, the problem isn't the transmission though. It's the shifter linkage, which binds if you put too much sideways pressure on the shifter to get over to 5th.
The secret is to push over enough to get past the spring tension, but not so much that you are rubbing along the shifter gate as you try to find 5th.
I imagine some adjusting could be done, but I haven't tore it apart myself yet and I don't really trust the dealer that much to work on my car.
It does slow the shift up to 5th slightly since you can't just bang it in, but do you honestly need to be shifting hard into 5th?
Desmo
Old Jun 2, 2003 | 03:20 PM
teh215's Avatar
teh215
8000 Mi = Warranty Issue. Even if it is small problem (or even common or insignificant) take it into the dealer so that it is documented. It may be insignificant but, if it becomes a larger problem at least you have shown diligence. Just my opinion.
Old Jun 2, 2003 | 04:37 PM
305z's Avatar
305z
Default get a new transmission at the dealer
get a new tranny....ASAP
Old Jun 2, 2003 | 04:49 PM
ricks350z's Avatar
ricks350z
ok heres the solution:
shift control lever to control rod bolt backed out reintalled shift control lever to shift control rod bolt.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
