Does anyone know what this problem is coming from?
Old Nov 14, 2007 | 09:07 AM
doreamon50's Avatar
doreamon50
Default Does anyone know what this problem is coming from?
hi everyone, the problem that I'm having with my car is my rear driver side suspension is making a clunking sound everytime when I hit an hard bump. I know there's a TSB about clicking rear suspension when the car stop and go, but my problem is when I'm going over bump, so I think is not the TSB. I just replace a brand new set of Toikco D spec shock and new spring, and the reason I replaced my suspension was I thought the suspsension was wearing out and it's make the clunking sound, but apprently it is not the spring and shock's problem. Does anyone know what might be the problem that I'm having. Thank You
Old Nov 14, 2007 | 09:16 AM
thrill350z's Avatar
thrill350z
I had rattling in my trunk area that drove me crazy and i just had to tighten the screw wing that holds down the spare/donut tire. It sounded like something more, something bad but that fixed it, good luck
Old Nov 14, 2007 | 06:44 PM
doreamon50's Avatar
doreamon50
thankz ranton73 I'll lift the car up to check the bolt this weekend, when you said lower control arm, where is that loacated at?
Old Nov 15, 2007 | 08:00 AM
Ztalker's Avatar
Ztalker
shim the rear strut tower where the strut is bolted to the two studs. That's probably where the clunk noise is coming from when you hit a bump or uneven pavement. i had that noise back in 03.
Old Nov 15, 2007 | 08:42 AM
Billhyco's Avatar
Billhyco
If you have to ask that, do you really think you should be bothering with this yourself? I mean no disrespect, However I do see a lot of DIY'ers come thru the service lane in worse shape then where they started. And typically less money in their pockets. Moral of the story, just take is some where reputable and have them do a visual check.
Old Nov 15, 2007 | 05:38 PM
Tim@WestCovinaNissan's Avatar
Upper and lower control arm bolts are common to be loose and making noise (front). Take it to someone to look at and if the don't visually see anything, have them tighten the control arms.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
