Problem between 2000-2500 RPMS
Old Jan 8, 2008 | 05:04 PM
mw9's Avatar
mw9
Default Problem between 2000-2500 RPMS
For the last 2 weeks I am having a problem between 2000-2500 rpms. It doesn't matter what speed or gear. The car will start to shake/stuttering, like it is struggling. First we thought it might be a bad tank of gas, but I have had about 3 tanks since then. Have no ideas, its weird, because its only between those RPMS. Any suggestions would be greatly appreciated.
Old Jan 8, 2008 | 08:43 PM
.steeeeZ33.'s Avatar
.steeeeZ33.
@ J&D auto
does it shake like the motor is shaking or shake like the car is shaking.. if so, does it only do it when u are accelerating?
Old Jan 9, 2008 | 01:08 AM
mw9's Avatar
mw9
Could be the motor, but it feels like the car. You have to be giving it some gas, you just can't coast in those RPMS. The motor needs a load on it, to have the problem.
Old Jan 9, 2008 | 01:46 AM
TheProfessional's Avatar
TheProfessional
Check your oil level.
Old Jan 10, 2008 | 12:23 PM
mw9's Avatar
mw9
Haven't check oil yet, but this problem is also happening. This is the second time this has happened. When I left work today, I was in 1st and shifted to second, when I was in second and gave it some gas it didn't seem to want to go anywhere. So I pressed harder down on the gas and it slowly went up in RPMS. No matter if you had the gas all the way down, the RPMS gradually increased. Once I drive the car for about a minute or two the problem went away and I could punch it and the car reacted fine.
Old Jan 11, 2008 | 05:06 PM
Zboostin's Avatar
Zboostin
Im having a similar issue with mine, but mine wont exceed more than 2500rpm.
Still trying to troubleshoot.......
Old Feb 12, 2008 | 11:24 AM
mw9's Avatar
mw9
Still have problem, heres the udate with 4 codes:
any help in figuring out this problem with be very much appreciated.
PO305-misfire has occurred in cylinder 5
1.ignition system fault-spark(plug), ignition wires, coil
2.vacuum leak
3.injector fault
4.high or low fuel pressure
PO132 sensor1 bank1
PO152 sensor1 bank 2
Po138 sensor2 bank1
1.bad 02 sensor
2.running rich
3.high fuel pressure-fuel return line blocked or pressure regulator defective
4fuel pressure regulator leaking
Old Mar 17, 2008 | 03:42 PM
menehune's Avatar
menehune
Have you found a solution to your problem?
I've been facing the same dilema, and I can't seem tp troubleshoot my problem.
Old Mar 17, 2008 | 04:13 PM
mw9's Avatar
mw9
Just bought some software that will let me run live diagnostics. But the weather has been too shitty to use it.
http://www.auterraweb.com/
Old Apr 13, 2008 | 10:15 PM
nightcrawler_8's Avatar
nightcrawler_8
any update on this ????
having the same issue in here.
i took my car to the dealer. got it checked by the console. and all the sensors are fine and the check gave 100% complete and sucsseful...
the last mod i did to the car before this problem started is :
1) changed new spark plugs ( OEM )
2) installed Throttlebody spacer (helix)
any ideas guys?
Old Apr 14, 2008 | 10:23 AM
nightcrawler_8
bump
Old Apr 14, 2008 | 11:00 AM
imjdoggie's Avatar
imjdoggie
Bad MAF or 02 sensors?????
Old Apr 14, 2008 | 11:04 AM
nightcrawler_8
i checked both .. and both are fine.
Old Jun 4, 2009 | 02:52 PM
PrOjEcT ZeE's Avatar
PrOjEcT ZeE
I have the same problem but I'm not in gear I'm in neutral, and when i rev it up (6000) it's fine, when it drops to around 1500-2000 it starts to vibrate. is that the same issue you have?
Old Jun 4, 2009 | 03:10 PM
ag4670's Avatar
ag4670
i hade a similar problem but mine was acting like it was going to die, this might help some people not everyone. i jacked the car up disconnected the o2 sensor after the cat just the green one passenger side and started my car up and the problem went away i never had the problem again. in my case with no tune running headers/exhaust and etc my car is running too lean killing my 02 sensors hopefully this helps someone
Old Jun 4, 2009 | 03:12 PM
ag4670's Avatar
ag4670
also try doing a ecu reset this link should help with the reset
http://www.technosquareinc.com/350reset.htm
Old Aug 20, 2009 | 10:36 PM
island03z's Avatar
island03z
any update on this?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
