rear axle flange bolt??? help !!!!!
Old Jun 17, 2003 | 03:16 PM
350ZZZZZZZ's Avatar
350ZZZZZZZ
Default rear axle flange bolt??? help !!!!!
where can i find the rear axle flange bolt, its rattling everytime i accelerate or decelerate. does anbody have a diagram of where it could be ?
i friggin tightened everything under the car on the passengers side suspension. i removed the wheel and retorqued the actual axle spindle nut !!!!
where the hell i s the axle flange bolt ?????????????????//
Old Jun 17, 2003 | 05:07 PM
westpak's Avatar
westpak
SFZCC
Remove the wheel and it is right in the center, it is huge, it is also called the hub nut.
Old Jun 18, 2003 | 02:05 PM
350ZZZZZZZ's Avatar
350ZZZZZZZ
i tried to retorque that nut, its tight as *****, i mean i almost stripped the ****'......
maybe i should remove it and lube the sum bissshh.
Old Jun 18, 2003 | 07:10 PM
westpak's Avatar
westpak
SFZCC
That has been the fix for some on the noise, they have relubed the shaft and the noise has gone away. The torque spec is 152-202 lbs, I would go with the 200.
