AC RPM problem
Old Mar 11, 2008 | 01:17 AM
Dreamsmith's Avatar
Dreamsmith
Default AC RPM problem
When i switch on my A/C the rpm starts going down and up again contantly, and the A/C doesnt cool, what is the problem?
Old Mar 11, 2008 | 04:20 AM
SNOW_WAGON's Avatar
SNOW_WAGON
is the a/c clutch engaging?
Old Mar 11, 2008 | 05:42 AM
jray8's Avatar
jray8
its natural for the rpm's to fluctuate as the alternators load is being adjusted in stop and go traffic, and if it doesnt cool, maybe u need a re-charge. but i have read a few post on here regarding the a/c and some suggest that since the car has the outside temp. monitor, it adjust itself based on that.
Old Mar 11, 2008 | 11:46 AM
Dreamsmith's Avatar
Dreamsmith
the problem is if starts fluctuating it doesnt stop after some time, it keeps on going up and down, and the A/C doesnt cool when this happens.
The thing is this doesnt happen always, only sometimes!
Someone told i should try to clean the throttle body it may fix the problem, will that work?
Old Mar 11, 2008 | 03:51 PM
Corradoslc7's Avatar
Corradoslc7
Fluctuating idle could be either a vacuum leak or IAC (idle air control) valve. Cleaning the throttle body and the IAC valve, which is attached to the throttle body, should take care of your problem.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
