Question about Red Locktite on flywheel bolt for install
Old Apr 5, 2008 | 08:31 PM
koolzero's Avatar
koolzero
Default Question about Red Locktite on flywheel bolt for install
I'm installing a JWT flywheel, and I have some concerns with using red locktite that is recommended. When I removed the bolts holding the nismo flywheel in it did not look like any type of locktite was used on the bolts. Do I have to use it? The red locktite won't make the bolts impossible to remove in the future, correct?
Old Apr 5, 2008 | 08:37 PM
Here is a good Loctite reference: http://www.mtariders.com/mctech/g010.shtml.
Old Apr 6, 2008 | 04:56 AM
DavesZ#3's Avatar
DavesZ#3
Loctite makes it difficult to remove, not impossible. It's mainly to keep bolts/nuts from vibrating loose, it's not a "weld".
Old Apr 6, 2008 | 05:06 AM
Sean's Avatar
Sean
Good idea.... get some JB Weld and squeeze it on the bolts prior to tightening.
Dr.Paulyy
Jul 29, 2019 07:45 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Suffolk350z
Sep 13, 2015 02:43 PM
