Constant Pass Rear Wheel Click..
Old May 1, 2008 | 07:53 AM
Zeebra's Avatar
Zeebra
Default Constant Pass Rear Wheel Click..
Need your tech savvy for a sec... Im getting a consistent clicking sound coming from my rear passenger wheel only. Its not the TSB rear axle click when starting because I fixed that.
Its sounds like on a bicycle every wheel revolution causes a click.. click.. click... I can only really hear it when Im next to a car or a wall or something. Any ideas? Damn annoying daily driver issues.
The wheel is tight/ my spacer is tight. I dont have slotted rotors or anything. Im running Hawk HPS Pads but have had them for like 7 months now.
Old May 1, 2008 | 07:54 AM
JSDZ33's Avatar
JSDZ33
rock in your tire? did you get out and look at the car yet?
J_Dizzle's Avatar
J_Dizzle
southcentral>me
you could have a screw in your tire and its tight enough to not be leaking air fast
Old May 1, 2008 | 07:55 AM
Zeebra's Avatar
Zeebra
Yea made sure nothing was loose... Sounds like a metal on metal clink instead of a rock or bolt hitting the road.
Old May 2, 2008 | 04:33 AM
JMD702's Avatar
JMD702
If it sounds like metal clinking around it could be a bearing i had the same problem for a while. the sound started off pretty subtle so i figured i jus needed new brake pads and as the noise grew more and more annoying and i removed the wheel i found out it was the bearing
Old May 2, 2008 | 05:08 AM
Zeebra's Avatar
Zeebra
Thanks for the help guys.. Actually took the wheel/spacer off and made sure nothing was rubbing... Checked the tire and nothing. Frustrated put everything back on super air gun tight and now no more click. Obviosuly something was loose. Scary!
Old May 2, 2008 | 11:45 AM
YellowZ58's Avatar
YellowZ58
There is a TSB about this. Take it to dealer for warranty fix
Old May 2, 2008 | 12:17 PM
lucky350's Avatar
lucky350
TSB 04-065 - Suspension Clicking Noise From Rear Axle
Old May 2, 2008 | 03:38 PM
jaaf's Avatar
jaaf
i have an 04, so i can justt take it to the dealer and they will fix it free of charge??
Old May 2, 2008 | 03:42 PM
Thumbs up
Old May 2, 2008 | 03:44 PM
Yes. Its a warranty fix.
Old May 29, 2008 | 06:41 AM
stealthguy3's Avatar
stealthguy3
i just called the nissan dealer and they said tsb's are only covered under 3/36 which is crap considering i have an 03. is that true or are they just being lazy?
Old May 29, 2008 | 07:16 AM
ZKansasZ's Avatar
ZKansasZ
I wonder the same thing...my 03 has the same problem as the OP!
ok, just called my local nissan and they quoted this:
"we charge 100 to bring it in for inspection, then at least 1 hour for our technicians to test drive it and put it on air to test, blah blah blah..."
Then I asked:"what if we already know what the problem is and just want to get it fixed?"
He said:"If you just want me to replace the rear differentiate(SP) then it's 79.95 plus tax"
hope this helps!
Old May 29, 2008 | 10:32 AM
Tim@WestCovinaNissan's Avatar
TSB's are not covered like a recall is. The warranty will only cover it if the part getting repaired is still covered under warranty. The axle clicking is covered by powertrain warranty 5yr/60k.
Old May 29, 2008 | 06:44 PM
Gingervitis526's Avatar
Gingervitis526
I took mine in to get the "click" fixed and it still does it(He told me the service dept greased everything up). Are there any long term effects of not fixing this? Will it ever come to a point where I need something replaced and not just greased? I have a bumper to bumper warrenty on the car for about 83 more days so I want to get as much fixed as possible before the cash starts coming out of my own pocket. Any subtle yet common things I should look out for?
Old May 29, 2008 | 07:17 PM
J_Dizzle's Avatar
J_Dizzle
southcentral>me
it doesnt hurt the car in any way. its just annoying.
all you have to do is to pull out the axles, turn them 180 degrees, put grease on them, and put them back in.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
samansharif
Sep 25, 2015 12:31 PM
