Battery Charge Problem
Old May 2, 2008 | 08:53 AM
TampaZ's Avatar
TampaZ
Default Battery Charge Problem
Hey everyone. I went on vacation and accidentally left my headlights on I must've not heard the tone cause I was in such a hurry to pull it into the garage while my family waited for me to get going. I returned from vacation a week later and my battery was completely dead that the remote key wouldn't let me in. I recently bought a yellow top Optima battery recently since I have a lot of electronics in my car and I heard it was the perfect battery, which it really was. Now I think the battery is so drained that even after a couple of drives around it still struggles a bit to start. I bought one of those portable chargers from Costco that has the cables to jump start it and was wondering...If I left the terminals connected to the portable charger while it was plugged into an outlet for a while to get the batter charged up completely, would that damage the car or car battery in any way?
Old May 4, 2008 | 06:22 PM
Z-MIKE-GO's Avatar
Z-MIKE-GO
If you are talking about the charger that is just meant to jump start the vehicle, then it is sending more amps than just a regular car charger. This charger is only meant to be used for short term. It would not be a good idea to use unless the battery is completely dead because long term use of such a high amp rate will shorten the life of your battery and could damage other electrical components. You really need a regular charger. As long as you keep the amps @ 12 or below. The best thing to do is charge it @ 1 or 2 amps overnight to get the best charge. Be sure that it is on the deep cycle setting because the optima battery should be a maintenance free battery (no caps to add water). I hope this will help.
Old May 5, 2008 | 05:09 AM
bluespecv03's Avatar
bluespecv03
Those portable chargers have a few settings usually. Switch it to a low amp setting and let it charge the battery. Don't leave the battery connected to the car though while you do this.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
