Stock Cat Install Help
Old May 29, 2008 | 08:07 AM
Bret86944's Avatar
Bret86944
Default Stock Cat Install Help
I have to get an emissions test so I'm taking my test pipes off to put stock cats back on.
I can barely get at the three bolts from the cat to the header and don't know what to do. Should I just use the factory studs and try to put a bolt on the other end? There's no real way to get at the top side of the flange, especially on the driver's side.
Any help would be great. Thanks
Old May 29, 2008 | 08:26 AM
HondaKiller's Avatar
HondaKiller
You have to go in through the top. remove your intake for the drivers side. Once that is removed it will take about 2-3 foot extension to reach it. ALL bolts from cat to header will be removed from the top of the car. Good luck mang, its a *****.
Old May 29, 2008 | 11:00 AM
Bret86944's Avatar
Bret86944
Dang, I was afraid you'd say that. I've got a couple extensions and a little ratchet universal joint that's good for getting bolts at angles. Hopefully I'll be able to reach down in there. Thanks
Old May 29, 2008 | 05:47 PM
Bret86944's Avatar
Bret86944
Alright, after two days of work, I have one stock cat and one test pipe on my car. I couldn't break the upper bolts loose on the passenger side. Looks like I'll be calling a shop...
Old May 29, 2008 | 06:00 PM
Asian Invasian's Avatar
Asian Invasian
I hope you have a breaker bar.. if not get one and try again it will save you alot of money. You can rent one at Autozone..
Old May 30, 2008 | 02:52 AM
Bret86944's Avatar
Bret86944
My buddy has an air gun. Still didn't work. I think a couple of these bolts need professional help. I can't wait any longer either because I need to get an echeck in order to register the car.
Old May 30, 2008 | 07:23 AM
HondaKiller
professional help = WD40 or some sort of thread lock lubricant. Believe me there is nothing about professional help with these cars unless the mechanic owns one. 9out10 shops will have their first expeirence working a Z with your car... sounds scary to me lol Good luck.
Old May 30, 2008 | 11:58 AM
SpoilsofWar's Avatar
SpoilsofWar
The answer to your problem is PB blaster. If you soak the bolts in that, and they still dont come off, chances are they are fused for good and they'll snap before they unthread.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Li1ag
Sep 28, 2015 02:07 PM
codek
Sep 28, 2015 03:03 AM
