Car died!
Old Jun 4, 2008 | 07:38 AM
theseb's Avatar
theseb
not to hijack your thread or anything, and i know there's a million reasons why this could happen, but was this resolved? i'm having a similar issue, but with some strange details to go with it...
Old Jun 4, 2008 | 05:37 PM
black3.5z's Avatar
black3.5z
I just plugged in my scan tool tonight and it told me crankshaft positioning sensor so I am goin gto go from there i will keep this updated.
Old Jun 4, 2008 | 08:21 PM
Blackbird CPV35's Avatar
Blackbird CPV35
please keep us updated, i had the same problem today and i changed the CPS 3 times and it still did the same thing. I am thinking its the flywheel
Old Jun 4, 2008 | 09:19 PM
gimpster621's Avatar
gimpster621
Originally Posted by JoeyFyed
My car acted the same exact way when my crank shaft posistion sensor went out.
i think thats the cause
i had a engine replaced and had the same problems. first it only happened when i went past 4k rpm, then 3, then 2. worst of all it happened at a meet so everyone thought i was a noob driver. needless to say i had it towed and turned out it the crank shaft position sensor wasnt seeped in right.
Old Jun 4, 2008 | 09:57 PM
black3.5z's Avatar
black3.5z
that is the exact same thing that is messed up with mine only mine was at 3 k then 2 then 1200 i am calling nissan canada tomorrow and see wha tthey say about the recall then call the dealer it is said to have a bad solder on one of the wires. I will keep you guys posted.
Old Jun 4, 2008 | 09:58 PM
black3.5z's Avatar
black3.5z
did you plug a scan tool into it or anything? or did you just change it because?
Old Jun 4, 2008 | 10:42 PM
gimpster621
koo gluck.
Old Jun 5, 2008 | 10:38 AM
Blackbird CPV35
this happened when i was on the dyno at Injected Performance. Hal plugged in the scan tool and it threw the a cps code, changed it out with 3 known working ones, swapped out the ecu, swapped out the haltech and the patch harness and still nothing. Hal ended up putting a scope on the voltage output of the crank position sensor and it had a very bad voltage signal. They think it is probably the flywheel
Old Jun 5, 2008 | 10:39 AM
Blackbird CPV35
what do you mean by "seeped in right"?
Old Jun 5, 2008 | 10:46 AM
gimpster621
thats what the work order said. prolly not secured tightly?
Old Jun 5, 2008 | 03:31 PM
black3.5z's Avatar
black3.5z
why would the flywheel have to do anything with it. I did just have a new one put in
Old Jun 5, 2008 | 03:41 PM
Blackbird CPV35
the flywheel has a plate machined on to it with little teeth notched out of it. That is what the crank position sensor reads off of. If there is a defect in the flywheel or it is slighly deformed then the sensor will not be able to count the teeth correctly and confuse the hell out of the ecu
Old Jun 5, 2008 | 03:42 PM
Blackbird CPV35
btw i also have an exedy clutch and flywheel, so that is a common link
Old Jun 5, 2008 | 04:00 PM
black3.5z's Avatar
black3.5z
ya i have a clutch masters flywheel
Old Jun 6, 2008 | 05:34 PM
black3.5z's Avatar
black3.5z
I am pretty sure i figured out my problem. i got under my car with alot of trouble only having a scissor jack. i found my sensor was actually loose and hung out a quater inch as you read this I am going to try my car right now.
Old Jun 6, 2008 | 06:20 PM
black3.5z's Avatar
black3.5z
ok so it was the sensor loose. thanks for all the help.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
