shifter bracket problem!! rear case f'd??
Old Jun 7, 2008 | 07:00 PM
iheartmyz's Avatar
iheartmyz
Default control lever housing problem!! rear trans case f'd??
long story here...and i need help please...
1. had an '03 track ed. z, the trans was replaced on that car and it ran like a beauty...
2. i crashed that z, took the engine, trans (CD009), spec stage 2 clutch, JWT flywheel, rims, dif, brembos...anything good really off before the insurance company took it back...
3. got another '03 track edition z with 36,xxx miles on it and it was running good for a bit...then started having minor trans (CD003) issues 3rd gear started to grind when i shifted up into it or down into it...every other gear was fine...
4. i decided to swap the clutch, flywheel, and trans and live happily ever after...or so i thought...
i put it all back together with the replacement trans...and hey, the bracket (control lever housing) that goes on the top of the trans and holds the shifter in place just doesn't seem to fit right...we put a couple spacers in and it seemed to be ok...but the shifter itself seemed to be like pushed back or angled back some...seemed weird but worked ok...
later that day, the shift linkage ripped apart, we looked at this bracket and came to the conclusion that there is no way that this bracket SHOULD fit...the distance from the upper bolt hole to the side hole on the rear trans case is 4 7/8 inches on the trans that is currently in my car (the 2007 replacement CD009). On the old trans (2003, CD003) and the control lever housing bracket the distance is aprox. 5 1/4 inches. Nissan insists that the trans i currently have in the car (CD009) will work with any bracket because there was only one bracket ever used....SOOOO that means the rear trans case on the CD009 is incorrect, modified, warped, ect. or the nissan tech I talked is retarded and there is a difference in bracket between the earlier and later transmissions. So should I...
A. swap the trans and deal with 3rd grind
B. go to nissan with my car and say "get the right bracket on my car"
C. try changing the rear trans case to fit the bracket i have
D. light my car on fire and get a honda
any and all feedback is appreciated in advance!!!
Old Jun 7, 2008 | 07:17 PM
Vegas_Speedster's Avatar
Vegas_Speedster
This bracket?
http://www.gzcon.org/zforum/showthre...8206#post28206
Old Jun 8, 2008 | 08:40 AM
iheartmyz's Avatar
iheartmyz
can't access that page...i just registered but i gotta wait for it to be activated....the bracket i'm talking about is the "Control Lever Housing"...seems like the rear trans case is different because the holes don't line up...but the control lever housing fits perfectly on my last trans...
Old Jun 9, 2008 | 06:11 AM
iheartmyz's Avatar
iheartmyz
anyone have any ideas??
Old Jun 9, 2008 | 06:46 PM
DozJr7's Avatar
DozJr7
bring it to a stealership and be done with it.. problem solved
Old Jun 9, 2008 | 07:46 PM
iheartmyz's Avatar
iheartmyz
yea they said they want $3000 to swap the trans...and didn't want to think about the problem i actually had...this was told to me at multiple dealerships...so any other ideas??
Old Jun 9, 2008 | 07:58 PM
iheartmyz's Avatar
iheartmyz
i'm pretty much leaning twards putting my old trans in and dealing with 3rd...or getting it rebuilt...i have no idea...
Old Jun 9, 2008 | 08:24 PM
DozJr7's Avatar
DozJr7
yeah I think that is probably your best bet then..
Best of luck man!
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
