Need Maintenance or installs?
Old Jun 13, 2008 | 09:39 AM
cpapasmurf's Avatar
cpapasmurf
Default Need Maintenance or installs?
30,60,90K Services
$380 this includes, spark plugs, air filter, brake fluid flush, power steering flush, automatic/Manual transmission fluid, diff fluid, oil change. If you have an intake no air filter change is needed. Spark Plugs are recommended every 90K but I reccmmend 30k so its your choice.
Spark Plug Replacement $174 including NGK Platinum Plugs
Exhaust Install - Cat Back System $75
Strut and or Spring install - Front $100.00, Rear $100.00
Test Pipes/ Catalytic Converter install $50.00
Intake Plenum install - Upper $90.00 i.e Kinetix V+
Plenum Spacer install $75.00
Header install $270.00 Now this price is for certain headers like the Forcefed which you do not have to remove the engine. The estimated book time is 6 hours for this job
Sway Bar instal $95.00
Front and Rear Brake pad replacement $60.00 per axle meaning $60 front $60 Rear - You supply the pads or I can get a few different brands including Nissan, Akebono, Advics etc and additional cost.
Big Brake Upgrade install $135.00 Per Axle and depending on the kit.
Cold Air Intake install $75.00 for cold air, and $50 for short ram.
Stero install - depends on what you are looking for
just email if you have any other requests or are interested in anything that I did not mention here.
Thanks
Chris
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
