i need help!
Old Jun 26, 2008 | 06:38 AM
04Z3E's Avatar
04Z3E
Default i need help!
yesterday i was driving home and my service engine soon light started blicking then steadly came on. every time i went back to 1st gear from every stop light my 1st gear was riding real shitty like dirty gas or bad plugs or i was thinking it might of been the fact that their is a recall on the fuel hose lines has anyone had this problem? or can anyone help me that might kno whats going on? thanks.
Old Jun 26, 2008 | 07:52 AM
Cant tell the players without a program
Stop by AutoZone and have the code read.
Old Jun 26, 2008 | 07:57 AM
2fast4comfort's Avatar
2fast4comfort
i would swing by auto zone and have your codes read. it could be not firing properly and you just notice it more in first because of the short gear ratio
Old Jun 26, 2008 | 08:28 AM
Swiffer's Avatar
Swiffer
Anything change recently? Oil change, air filter, etc...
Old Jun 26, 2008 | 04:18 PM
04Z3E's Avatar
04Z3E
yeah i changed me oil to royal purple and fram oil filter
Old Jun 27, 2008 | 01:49 PM
cpapasmurf's Avatar
cpapasmurf
Hmmm and this happened right after you changed the oil and filter? The service light would not set any codes that would be the check engine light. Its a possibility that the vehicle was not compadible with the oil and filter. Did you do the oil change yourself, or you had it done at a quick lube? Might want to check and make sure the airbox and all connections are ok. Oil Changers are notourus for leaving things loose.
Old Jun 27, 2008 | 02:49 PM
WhiteNoiz's Avatar
WhiteNoiz
+1 on getting your code pulled at autozone.
*note, royal purple has horrible wear numbers for the VQ
Old Jun 27, 2008 | 03:41 PM
Tim@WestCovinaNissan's Avatar
The service engine soon light is the check engine light on nissans. Go get your codes checked.
Old Jun 29, 2008 | 09:00 AM
Corradoslc7's Avatar
Corradoslc7
As Tim pointed out 04Z3E's problem has nothing to do with the oil. A flashing CEL points to an extreme misfire which could damage the catalytic converter. 04Z3E should have shut the car off as soon as the CEL started to flash, but now that it's on steady just go get the car scanned.
Old Jul 1, 2008 | 07:08 PM
Question
What did the scan reveal?
