2003 350z automatic stuck in park::: HELP:::
Old Jun 28, 2008 | 02:29 PM
dkd96's Avatar
dkd96
Default 2003 350z automatic stuck in park::: HELP:::
Hi i have an 2003 350z and my automatic shifter wont let it go in drive it does not let in go in drive untill i keep messing with does anyone know how to fix it thanx?
Old Jun 28, 2008 | 02:33 PM
mysterymann's Avatar
mysterymann
sounds like you have a problem
Old Jun 28, 2008 | 02:40 PM
stein's Avatar
stein
I'd check into the safety switch (or whatever it's called) which requires you to depress your brake to move out of park.
Old Jun 28, 2008 | 02:57 PM
stein's Avatar
stein
06 has a cable connected between the key and the shifter. Not sure about the 03 but I'm sure it isn't too different...
Attached Thumbnails 2003 350z automatic stuck in park::: HELP:::-interlock.jpg
Old Jun 28, 2008 | 03:48 PM
MrKaira's Avatar
MrKaira
Really MrZ31
call the place you bought it from, or a local shop. you've got to know someone thats a mechanic, or if not someone who knows someone who is a mechanic.
my old 03 automatic could be finicky sometimes.
Old Jun 28, 2008 | 04:02 PM
marhot's Avatar
marhot
Originally Posted by dkd96
....untill i keep messing with...
Huh?
Explain.
Old Jun 28, 2008 | 05:04 PM
35Z's Avatar
35Z
Question Auto trans shifting problem
I am unclear the circumstances when you shift into a gear (drive only and not reverse). Is this a problem all the time or a random occurance?
How many miles are on the vehicle? Has the automatic transmission fluild been changed? Nissan suggest changing the automatic transmission fluid at 60K miles which takes 10 7/8 qt of Nissan ATF matic fluid J.
Old Jun 28, 2008 | 07:57 PM
carlili4190's Avatar
carlili4190
depress the break... and then pull the little lever... and put the car into drive
Old Jun 29, 2008 | 03:20 PM
Ruthless18x's Avatar
Ruthless18x
You didn't leave the key in the ON position now did you?
Old Jul 4, 2008 | 08:12 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Definitely check that.
Also as one of the others has pointed out, how long since or has your Z had a trans flush and replaced fluids?? That will make a huge difference. I had my Z done at 60,000 kilometres, much smoother. Will normally be a bit stiff when it's cold first thing, same as every tip-tronic 350 I've driven, irrespective on NZ new or JDM.
Old Jul 4, 2008 | 08:30 PM
z350boy's Avatar
z350boy
There's only one fix.....but a Z with a M/T !!!!!!***
Old Dec 11, 2008 | 09:15 PM
abigroman's Avatar
abigroman
My 03 Z is doing the same thing but I physically pulled it down. Now it won't jump into the tiptronic mode at all. I paid Nissan $100 to tell me that the cellenoid in the gear shift needs to be replaced.............for a mere $800! I think they are full of ****.
Old Apr 18, 2009 | 11:24 AM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Question Did...
this ever get resolved? Covered under warranty?
Old Apr 18, 2009 | 01:35 PM
marhot's Avatar
marhot
Holy thread resurrection, Batman!
Old Apr 20, 2009 | 03:04 PM
abigroman's Avatar
abigroman
Default So.........A month later!
So a month later it some how comes unstuck! $800 dollars my ***!!!!! They were just trying to **** me over! I still got stuck with a $100 inspections fee. I will never take my car to the dealer again!
Siqcology
Sep 18, 2019 01:45 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
foxsmp26
Sep 25, 2015 09:48 AM
RWDBajan
Sep 8, 2015 06:25 AM
