Having very weird electrial problem!
While im driving all the dash electrical with just shut off, a/c,radio,dash lights,etc. After a few minutes then it will come back on. What kind of a problem am i looking at here, can it be a faulty fuse or something else?
You might also want to check that you are not running into a loose ground wires somewhere. I know this is kinda like finding a needle in the hay-stack, but its usually a simple and cheap fix.
I have had this happen to me in my old k-1500 blazer and I basically had the same symptoms as you. This is what it turned out to be. I ended up finding the wire was loosely making contact, and then randomly losing it causing the short.
Just an idea....
Just an idea....
Just an idea....
Just an idea....
Chris, Check the connections of + or - on your little Braille battery. Remeber it was sitting on top of styrofoam? Maybe it shifted and one of the terminals are lose. It happened to me when I installed the Optima Battery. Check it before you leave work.
