Need some assistance
Old Jul 17, 2008 | 01:30 PM
SeannMikee's Avatar
SeannMikee
Default Need some assistance
Whattup Fellas.
I was just driving and i noticed that the gauge where it displays the digital spedomator and temperature etc. in my car is completely blank all of a sudden not lighting up. So can someone help me out and try and tell what the problem is.
And also my oil light just popped up, even tho i just recently got my oil changed and i have a little over a thousand miles left til my next one, the oil gauge is reading at zero while i am dailing driving. So if someone has some input that would be great.
Thank you.
Old Jul 17, 2008 | 01:32 PM
raulzito's Avatar
raulzito
Your car is either mad at you or needs Gas!~
Take it apart, check it out the connection
Old Jul 17, 2008 | 03:00 PM
R-TuneZ's Avatar
R-TuneZ
why the f*ck are you driving around when you have no oil pressure and your oil light is coming on? you are going to blow your engine, the oil light is a warning for extremely low oil pressure. you most likely have a leak somewhere in the system... i suggest you stop driving the car around and bring it in for service... use a tow service, STOP DRIVING YOUR CAR.
have you considered checking your oil using your dipstick...?
Old Jul 18, 2008 | 03:14 AM
CancerJCCz's Avatar
CancerJCCz
Whoa easy Mr. Logical! lol
Old Jul 18, 2008 | 08:38 AM
OldDirty Z33's Avatar
OldDirty Z33
OMFG do you have any common seance???? Flame suit aint going to work this time dum a** I dono check your oil dip stick get it towed to the local mechanic and get that ***** fixed!!! Your crazy man.
Old Jul 18, 2008 | 09:51 AM
VO...'s Avatar
VO...
Administrator
Ease up fellas. OP, as suggested, have you manually checked oil levels with your dipstick?
The cluster guage plug behind the cluster may have become dislodged. Have you removed the panel lately to install a new HU?
Old Jul 18, 2008 | 11:03 AM
HondaKiller's Avatar
HondaKiller
lol all these new members ripping this guy apart.
I had problems with my gauges not working one day too. I couldn't explain it, i was so heated i turned around and started heading back home. i turned down the street and BAM everything lit up. As mentioned above the plug was loose from me foxing with it when installing my system. Let us know if you find anything.
350z_z33.
Jul 3, 2017 04:01 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
