Wierd hum on the highway
Old Jul 26, 2008 | 08:16 AM
Miketsi's Avatar
Miketsi
Default Wierd hum on the highway
Sounds like it coming from the rear of the car. Anything above 60mph, if you turn to the right at all, you can hear a loud humming, goes in and out. If you're going straight, or turning left, nothing. Could this be a wheel bearing, uneven tire wear?
Whatcha think?
Old Jul 26, 2008 | 05:40 PM
magna750's Avatar
magna750
Sounds like tires to me.
How many miles on your car?
Old Jul 26, 2008 | 05:53 PM
cheshirecat79's Avatar
cheshirecat79
Sounds like tires caused by an alignment issue that has worn down a rear tire unevenly.
Old Jul 26, 2008 | 06:58 PM
brandon85's Avatar
brandon85
probably wheel bearing, unless youe tire are cupped or bald on the inside edge
Old Jul 26, 2008 | 07:10 PM
brandon85's Avatar
brandon85
if you can securely raise your rear tires off of the ground and get someone to drive it at 60mph while you listen, without the weight of the car on the bearing you might not hear anything. its worked for me though.
Old Jul 27, 2008 | 07:11 AM
Miketsi's Avatar
Miketsi
I just got an alignment, I really think its a wheel bearing.
My car is an '04 with 22k miles. Do wheel bearings go out alot on these things?
Old Jul 28, 2008 | 11:30 AM
sixsigmalarry's Avatar
sixsigmalarry
Wink Try this...
Miketsi (did you have a DSM?),
A simple test to determine if you have bad wheel bearings. It's not 100%, but it's worked for me in the past.
First, get your Z off the ground to check the suspected wheel. If you're not sure which side or tire it's from, you'll have to do this for EACH wheel.
Once you get the wheel off the ground, place your hands on opposite sides of the wheel (12 and 6 o'clock, or 3 or 9) and try to wiggle the wheel. If the wheels has a little play, you may have a bad wheel bearing and the root cause of your issue.
Then again, it could be uneven wear on the tires.
Check....it's easy! Good luck!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
wanderingstuden
Jan 28, 2016 07:03 PM
kyin
Sep 29, 2015 06:57 AM
CrowzRSA
Sep 21, 2015 04:00 PM
FromGtoZ
Sep 20, 2015 03:41 PM
